RB Concept Engine Thread..
#2761
Picked up a Matt Russell moded B11/2087.I have put about 1.5 lrs through it and started to lean on it a bit today. Running in a RC8T this thing is awsome. Plenty everywhere but more torque than agressive, 9.30 min still running an hour or 2 on the rich side compaired to 8.00-8.30 with an Alpha A852/0801. Motor does not have the bottom end of the alpha but it gets the power down a lot easier. Was unsure how it was going to go in a truggy but am very impressed with how it goes.
#2766
I have a 2058 pipe, I forgot that I bought one on amain when they were selling Nvision parts on sale,I took a pic of the 2 side by side, you can see the difference. Oh, and I picked up a fire 11 on eBay, had 2 tanks of fuel thru it, 150, I want to try it out. What size restrictor did you run?
#2767
#2768
I
Mostly race truggy, so it should be fun, how is the fuel mileage for that engine? About the same as a C6? We usually race at night time out here, its to hot in the day time. We used to run the 8 plug only way back when.
#2769
#2771
I do always get the best mileage with the 2045 and 192 header. Also if you have a carb from an old WS7 you used to run or an older C6 you may want to put that on the F11. The carb it has will work fine I just do not like having the idle screw on the front of the carb like the F11 came with.
#2775
How is the new Fire compared to the Fire 11? Even if just on paper, should one expect more power from the newer version? The main thing stat-wise is just that the new version is a 7+2, the Fire 11 a 7+1...
New Fire:
Competition racing engine
7 ports + 2 by pass
Lightened conrod
Turbo plug
Turbo combustion chamber
14mm bi-turbo crankshaft (long stroke)
14mm rear bearing
9mm nylon carburetor with 9mm venturi included
L2G cooling head
Strengthened crankcase “black coated”
Aluminum orange anodized wrist pin
Dust protection caps
Looks like the kit version here even comes with the bearing cover for behind the flywheel...
New Fire:
7 ports + 2 by pass
Lightened conrod
Turbo plug
14mm rear bearing
L2G cooling head
2Likes
