Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Rw modding and engine rebuilding >
Like Tree28Likes
Old 07-24-2013 | 01:37 PM
  #286
YANMAN's Avatar
Originally Posted by 22Racer
Got one on the bench breaking in, cant wait to run it!
Great engine. I love mine and it is still fat. I am about at the 1 gallon make starting to lean her out.
YANMAN is offline
Old 07-26-2013 | 04:09 PM
  #287
Motorman007's Avatar
WOW Rex.
I just got my X5 back for you. I sent if off to you asap after the Pro Race in Dallas
It was so nice and clean I was thinking I had a New motor.
Thanks again.
Rex is very good guy and I will for sure buy from him again HIS CUSTOMER SERVICE IS WONDERFUL.
Dibbs
Motorman007 is offline
Old 07-26-2013 | 06:19 PM
  #288
rider313's Avatar
I have sent Rex motors ready for the garbage can and get them back sparkling clean and running great. Only guy I will send my motors to.
rider313 is offline
Old 07-27-2013 | 07:21 AM
  #289
ovalracer1m's Avatar
+1. Rex is the man.
Need a new mill for truggy. I have been eyeing up the maxy cinco or maybe that X7 that you have leftover. I will get ahold of you Monday.
I have a alpha 2090, werks 2058, and a ofna 086. The vid at teas with the 2090 pipe looked like it ran well with the x7
ovalracer1m is offline
Old 08-07-2013 | 05:16 PM
  #290
22Racer's Avatar
In the last week or so rebuilt a few "modded engines" from 3 different companies, lets just say I was not impressed with any of them. Most charge $80-$100 more and I am pretty confident that it would be less than a 5% improvement.
Here is a pic of an Alpha crank I drilled before silicone, some guys barely drill in at all and fill it.
The last engine I worked on looks like it came from Australia, they have some pretty wild engines down there. The thing that disturbs me about this is it takes away so much counterbalance weight. And the crank window was really opened up also.
Sleeve pic from the Go
22Racer is offline
Old 08-07-2013 | 05:19 PM
  #291
The guy that mod that engine is at least butcher....
maragos is offline
Old 08-07-2013 | 05:23 PM
  #292
Hoese37's Avatar
That crank looks identical to a guy on ebay..
Hoese37 is offline
Old 08-07-2013 | 05:28 PM
  #293
Maximo's Avatar
yikes those do look quite rough...
Over the years I have had all sorts of "modded" engines pass thru my shop... I actually dyno tested most of them while I had them... A 5% gain would have been a blessing compared to a few that I tested as they actually lost substantial power over stock due to the damage that was done them.....
Maximo is offline
Old 08-07-2013 | 05:54 PM
  #294
22Racer's Avatar
I imagine Neal, I have respect for what you know about these engines. I know you can make some big power and invest alot of time. The 5% engines I was talking about was barely touched, not like this pic.
Rex
22Racer is offline
Old 08-07-2013 | 06:02 PM
  #295
Maximo's Avatar
Rex
All good dude !
As a general rule I would say that the more visible a modification becomes, the less beneficial that modification will be to the engine...Of course like anything there is some exceptions... but they are of course the rare exception .....
Maximo is offline
Old 08-07-2013 | 07:05 PM
  #296
houston's Avatar
Yikes
Thats craziness
doesnt look that tini coating worked out to good
houston is offline
Old 08-07-2013 | 07:08 PM
  #297
Originally Posted by Maximo
All good dude !
hey rex i heard that you carry the buku caps for the lutz. did you make them fit with out grinding on the block. If so shot me a pic cause im not grinding away on that nice block. Thanks rob
imrob is offline
Old 08-08-2013 | 03:47 AM
  #298
rider313's Avatar
Rex machines a groove in the block. He posted this pic a few pages back.
rider313 is offline
Old 08-08-2013 | 06:09 AM
  #299
hey rob, if you do not want to machine the block, the alpha specific caps work ok. You just may need to run a locking compound that buku sells to secure the cap in place since the end of the case has a cast, tapered snout to it. Some also just use a rtv silicone.
Another option you can do to help the cap fit better without fully machining the block it to just ever so slightly machine the block to just true up the end of the block and take the high spots off (pic below) This also works ok.
But overall, the full machining of the block to fit the nova size is the best overall solution as dan posted above. The cap fits on the block very well with no distortion, and no locking agent is needed. It gives you the peice of mind that the cap will stay in place. I would highly recommend that route
Attached Thumbnails Rw modding and engine rebuilding-20130610_234132_zps6efdc12b.jpg
Old 08-08-2013 | 08:12 PM
  #300
houston's Avatar
Originally Posted by ovalracer1m
hey rob, if you do not want to machine the block, the alpha specific caps work ok. You just may need to run a locking compound that buku sells to secure the cap in place since the end of the case has a cast, tapered snout to it. Some also just use a rtv.
i love that there is a nova 17011 front bearing in that alpha ,
keep up the good work Rex !!
houston is offline
