Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Rw modding and engine rebuilding >
Like Tree28Likes
Old 07-03-2013 | 03:00 PM
  #271
22Racer's Avatar
Got some Maxy Cinco engines on the way!
Ran the Trackstar/Alturn engine in a truggy today, man these are impressive engines for the $, no problem powering a truggy.
Rex
22Racer is offline
Old 07-03-2013 | 03:11 PM
  #272
RCmayor's Avatar
For the app I think some basic engine dimensions would be good. BorexStroke, Crank pin, Rear Bearing size, etc. Stock Head clearance. I'd pay $1. :-)
RCmayor is offline
Old 07-09-2013 | 07:17 PM
  #273
22Racer's Avatar
Sneak peek
22Racer is offline
Old 07-09-2013 | 07:28 PM
  #274
sschultz's Avatar
Originally Posted by 22Racer
Sneak peek
Nice! Will it be available for all engine makes?
sschultz is offline
Old 07-10-2013 | 06:14 AM
  #275
Motorman007's Avatar
Sneak peek
Is that a bearing?
do you just push out the brass part and put the bearing in?
Motorman007 is offline
Old 07-10-2013 | 03:20 PM
  #276
wingracer's Avatar
This is not a criticism so please don't bash me for spewing my own inner thoughts out loud.
I would be really surprised if the bearing holds up for long. It's got to take an awful lot of punishment. I really hope it does though, something like that could be a real game changer.
Then again, if it's cheap enough and easy to replace, hell just get it to last a full day of racing. If it can last for 2 hours of running and only costs $5 and a few minutes to replace, I'd do it in a heartbeat.
wingracer is offline
Old 07-10-2013 | 03:37 PM
  #277
rider313's Avatar
It would be like changing clutch bearings internally. Lol
rider313 is offline
Old 07-10-2013 | 03:52 PM
  #278
wingracer's Avatar
That's exactly what I was thinking about half way through writing my post.
Old 07-10-2013 | 04:16 PM
  #279
22Racer's Avatar
The first attempt with these bearings (there are 2 in there) was not good, it did not last long. There is alot of force there and the only bearings I could find are just $1 ones. I did take the seals off for fuel to get in there. I had to turn down the crank pin to 4mm, of course I stroked it a little Then bored out the rod. If I could find something that would work it would be awesome as you could take a worn crank and rod and make it new again. It did seem to rev better.
Latest project, machining blocks for Buku caps. I am also going to sell the caps, I am looking at about $15.00 to machine the block if sent bare or can be combined with a rebuild for $10.00.
22Racer is offline
Old 07-10-2013 | 06:04 PM
  #280
sschultz's Avatar
Nice work!
sschultz is offline
Old 07-14-2013 | 01:43 PM
  #281
22Racer's Avatar
Got one on the bench breaking in, cant wait to run it!
22Racer is offline
Old 07-14-2013 | 01:55 PM
  #282
Price???
maragos is offline
Old 07-14-2013 | 08:53 PM
  #283
22Racer's Avatar
The Maxy Cinco sells for $279.99, I should have Buku caps here Monday also.
Rex
22Racer is offline
Old 07-19-2013 | 03:21 PM
  #284
22Racer's Avatar
I am also modifying clutch's for the Buku caps if they are a recessed that will rub on the cap.
I will not be able to service/ mod any engines from July 24-30th.
22Racer is offline
Old 07-24-2013 | 01:29 PM
  #285
do you have parts from the trackstar engines or the alturn?
maragos is offline
