Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Rw modding and engine rebuilding >
Like Tree28Likes
Old 04-03-2011 | 05:34 PM
  #136
Redvet79's Avatar
Default MG66
Well got my mg66 back from Rex the other day and ran it today for the first time. Ran it around slow for 3 tanks only because it still had a good bit of mech pinch. Then started to lean it out. The Rex magic started to come to life after 6 complete tanks still just a tad rich temp 245 good smoke it was HOOKED UP pulling front wheels about 1" at the start of the straightaways.
13min run time with more in the bank.
I'll tell you what i am super happy. Running mbx6t 13t pinion 44t spur and plenty of bottom end. Novarossi ceramic bearings front and rear.
Thank You Rex
And Thanks to Bigmatt for the referral.
I also turned down some parts and replaced some.
Rotating Mass
Before After
Conical Diff Gear X2 44g 34g
Front Rear Outdrives X4 36g 24g
Center Diff Outdrives X2 20g 14g
Steel To Alum Axel Shaft X4 36g 16g
Drive Shaft Joint Cup Alum X2 20g 6g
Plastic Spur Gear 44t 30g 12g
7075 Alum Screws Diff & Spur X12 6g 2g
Total Grams 192g 108g
Saved Grams 84g
Saved Oz 3oz
Redvet79 is offline
Old 04-11-2011 | 04:38 PM
  #137
22Racer's Avatar
Now that it is nice outside it is time to experiment! Trying some different idea's for mileage. I make and sell exhaust restrictors (seperate piece)but never really liked using the longer spring to hold the header on. This one is internal (Exhaust pic)
Rex
22Racer is offline
Old 04-11-2011 | 08:36 PM
  #138
Integra's Avatar
Interesting.....
Integra is offline
Old 05-08-2011 | 05:16 PM
  #139
rider313's Avatar
Rex,
How did that crank mod work in the argus?
rider313 is offline
Old 05-09-2011 | 04:46 PM
  #140
22Racer's Avatar
I wanted to test it and then I figured I would just mill it out and open it up. After my initial test at Tea's I figured I should race it at Mnrc round 1. I was really suprised how it didn't really drop the top end much. All the air going through these small holes and the thing still kept up with almost everyone on the straight. Fuel mileage was really good, after a 5 min qual the tank was above the seam in the tank on a Losi. We run hot loop and come in for fuel 1 minute before the start and are usually on the track for 7 minutes by the time we finish. I pitted at 10 minutes in the B although the motor went slightly rich at the end and I didn't have much left after the race.
I was still able to clear the back table top at this track. (32 feet with a short runup)
http://www.facebook.com/permalink.ph...p?id=527166243
Rex
22Racer is offline
Old 05-31-2011 | 07:52 AM
  #141
FLHX1550's Avatar
This past weekend, Kendall Welch won both Pro Buggy and Pro Truggy at the JConcepts Spring Nationals in Omaha, NE running RW Modded Dynamite .21-XPE engines.
FLHX1550 is offline
Old 05-31-2011 | 09:56 AM
  #142
Integra's Avatar
AWESOME job Kendall, Way to represent.
Pic looks oddly similar to last years with Ruona in 2nd
Integra is offline
Old 09-16-2011 | 03:13 PM
  #143
22Racer's Avatar
Rw mods now carries Avid bearings! Excited about this and have had great luck with them.
Rex
22Racer is offline
Old 10-25-2011 | 02:57 PM
  #144
22Racer's Avatar
Congrats to Kendall for taking the Mnrc 1/8 buggy, Truggy and Short course championships again this year.
Kendall was running a prototype mod on his truggy motor at the finals and from what I hear it really ripped. (I was bummed I couldn't make it)
Rex
22Racer is offline
Old 10-25-2011 | 04:13 PM
  #145
rider313's Avatar
Rex
Now that i think of it his motor did seem differnt screaming down the straight.
Congrat Kendall
rider313 is offline
Old 10-26-2011 | 07:37 AM
  #146
Integra's Avatar
Congrats to Kendall and Rex, A True Champion is humble in his Victories and This is exactly how Kendall handle's himself. I look forward to racing with him and the MN crew for Years to come.
Yes Rex the Truggy motor was Pretty snarly this past weekend. Good job buddy. Curious what it'll do on the Dyno ?
Integra is offline
Old 10-26-2011 | 07:49 AM
  #147
pickle311's Avatar
I ran my P5 that I sent in for you to pinch this weekend and the motor felt great. It ran perfectly all weekend and had plenty of power. Thanks for fixing this motor up for me. I have probably 10 gallons on it and it's never run this well before.
I'll be sending some more work your way soon.
pickle311 is offline
Old 10-26-2011 | 08:45 AM
  #148
notproyet's Avatar
I have had RW Mods do all our race motors this year, and they have all ripped! Also had Rex do some work on my daughters engine to set it up more for a beginer. We ran the exhaust restrictor also and worked great! Fuel milage was awesome.
Thanks RwMods for a Great 2011!
notproyet is offline
Old 01-29-2012 | 07:09 PM
  #149
BSchorr's Avatar
R/C Tech Elite Member
Rex, you have PM!
BSchorr is offline
Old 02-18-2012 | 11:26 AM
  #150
22Racer's Avatar
Spring special!
Free Avid double sealed front bearing with a motor rebuild, price is $38.00 and includes return shipping. Any other parts are extra of course. Rebuild includes, teardown, cleaning, inspection of bearings, rod, crank, etc. Sleeve resizing, replacing front bearing.
Rex
22Racer is offline
