REEDY .21 Nitro Engine
Old 06-30-2010 | 12:25 AM
  #1021
808gx7r's Avatar
everyone may not know this. but the reedy is a LONG needle type low speed. so from this, you DONT GET A TUNE OFF HSN. as the bar stays in nosel the whole throttle band, you have to stay rich enough on hsn(this is why people end up with 10+ mins and 270F)
richen HSN alot. lean LSN and adjust idle to what it should be .5 to .7max.
will give you power + speed.
the ideal temp is 240-250.
checkout the go engine thread. they tune the same...
p.s don't tell me otherwise. me an a mate just bought 3. broke in the same, tuned off low end. 220F'ish on all 3 engines(different buggys, 808, mp777WC, and a mbx5.)
after 2 hours continous running doing 8:30mins a tank(pitting with like a 3/4 of a cm of fuel left in tanks.
all have just over a gallon through them
808gx7r is offline
Old 06-30-2010 | 12:29 AM
  #1022
RUNNINONMT's Avatar
will you end up with less run time if you tune this way cause 10 mins @270 inst that bad but 10 @240 would be the sh!t.....
RUNNINONMT is offline
Old 06-30-2010 | 12:35 AM
  #1023
808gx7r's Avatar
it uses the fuel better.. checkout the go engine thread on how to tune it better. my GX7R %$^$'s on the reedy run time wise. + speed
808gx7r is offline
Old 06-30-2010 | 12:39 AM
  #1024
RUNNINONMT's Avatar
ok so your saying that you did this on a go engine and not a reedy
Old 06-30-2010 | 12:44 AM
  #1025
808gx7r's Avatar
let me explain, the reedy has same carb design(other then mount posistion) as the new go engines, (gx series) so i try'd tuning the same... it worked the same as the go's and they are good engines.
808gx7r is offline
Old 06-30-2010 | 12:50 AM
  #1026
RUNNINONMT's Avatar
Thumbs up
ooooohhhhh i see thanks dude
Old 07-03-2010 | 06:41 PM
  #1027
R/C Tech Elite Member
I have tried the new AE 2039 tuned pipe with the Reedy 121VR. The pipe really woke up the engine.
Anyone else uses the same combo?
Sylvain is offline
Old 07-03-2010 | 06:46 PM
  #1028
RUNNINONMT's Avatar
you using this in buggy or truggy?
Old 07-04-2010 | 04:11 AM
  #1029
RJSI's Avatar
The 2039 is the option to have. I run mine with an RE10 and is fast, I can't to get my hands on a 2039.
RJSI is offline
Old 07-04-2010 | 06:02 AM
  #1030
I have this engine/pipe combo in a RC8TCE. I read people complaining abut the lack of RPM, I didn't feel any lack of RPM with the 2039 pipe.
I have to try a 2035 tuned pipe just to see the difference between both pipes.
Sylvain is offline
Old 07-04-2010 | 06:14 AM
  #1031
Charles Godwin's Avatar
2039 here was running it yesterday (with my engine that hasn't even seen half a gallon yet). Was keeping up with the NovaRossi's and still had good snap out of the corners. Definetly an improvement in top end
Charles Godwin is offline
Old 07-04-2010 | 06:19 AM
  #1032
Are you using it with a 121VR?
My 121VR is at its 9th tank and I have GREAT performances and the temp never gets above 220F. Idles well, has great powerband and now excellent top end and holds its tune perfectly.
Sylvain is offline
Old 07-04-2010 | 07:11 AM
  #1033
Yea using it with the 121vr Think mine has had about 17 tanks so far (12 being run on the box at WOT, Cyrul method). Haven't a clue what temps it comes in at but it works better than the 2035 imo just because of the top end running a P4 plug too as the Reedy ones are a tad expensive for just a plug....
Old 07-06-2010 | 08:31 AM
  #1034
Rick Hohwart's Avatar
Originally Posted by mcion
I love this reedy motor, but has anyone had the silicone crank insert disintegrate. The only thing I have cleaned the crank with is WD40. Also, can I run the motor without the insert? I really want to use my car tomorrow, as i just purchased 2 new piston and sleeves.
If your crank has lost the silicone you an sent it back to AE/Reedy for a new crank.
Rick Hohwart is offline
Old 07-06-2010 | 07:02 PM
  #1035
Andrew_67's Avatar
I`m just getting ready to break in my second Reedy 121VR, first one i stretched the con rod in under two gallons which i have figured happened during break in. I have broken in motors before but i`m by far a pro, a couple of friends have sent me there break in methods but i would like to hear from others that have broken in these Reedy motors.
You can PM me and i will send you my email address.
Any help would be great, can`t afford to be buying new motors every 2 gallons....lol
Thanks !
Andrew_67 is offline
