REEDY .21 Nitro Engine
#1054
i hear yah. thats what i was told..made sure to wright it down while i had the guy one the phone and double checked with him too..
still dont know why this isnt in the manual..everyone seems to have a different factory setting..first engine ive purchased whhere the factory settings are a mystery..
#1055
#1057
Thanks for your help guy`s, got it close, but it seams to bog after take off...lol...once i get a bit off speed, say around a hair pin and punch it it hesitates for a sec or two and then takes off again. I`m no set up tuner guy, i know the basic`s but that`s about it.
By the way, that .82mm and flush thing, my truggy won`t even start with those settings, had to go a real hour and a half in ( HSN ) just to start it, idle set at 1mm and a bit...approx.
Tomorrow i`m going to try the factory settings suggested, thanks again !!
#1058
lsn flush lean lsn if it wont idle... dont touch idle screw ever after its .7-.8
#1059
#1060
#1061
those settings are too lean, at least for floridas climate. we are closer too bottom= 4 3/4 out
top= 2 1/2 out
race tuned.
as Brandon mentioned, you should try and learn to tune it for your needs, should also mention that this engine will give a different temp. reading from button to case which is unusual, most engines will temp. the same is these two locations or be pretty close, this engine when up to temp. you may see 270 at button, but at the case you will see 240. not sure why, I would think the case temp. is the important one, anyone else notice this ? any ideas ?
Jay
top= 2 1/2 out
race tuned.
Jay
#1064
