REEDY .21 Nitro Engine
Old 07-30-2010 | 10:54 AM
  #1066
Front-7x19x6
Rear-14x25x6
Kubson is offline
Old 07-30-2010 | 04:32 PM
  #1067
d8racer3's Avatar
Originally Posted by Kubson
Front-7x19x6
Rear-14x25x6
Thank you. What is a good bearing to use? On a pretty tight budget. The rear bearing sound and feels really gritty.
d8racer3 is offline
Old 07-31-2010 | 02:09 AM
  #1068
808gx7r's Avatar
check go engines sizes. very cheap but very good bearings... they last FOREVER
808gx7r is offline
Old 07-31-2010 | 06:46 AM
  #1069
Stay as far away from Go engines as possible and all it's branches.
Chris Reilly is offline
Old 07-31-2010 | 06:58 AM
  #1070
d8racer3's Avatar
I was looking at the boca steel set they have for 29.95. Anyone have any luck with them?
d8racer3 is offline
Old 08-17-2010 | 01:11 PM
  #1071
yannis's Avatar
Default REEDY 121 ST
Hello
I would like to buy a reedy motor but I know that a new must go out anybody can say to me when
thanks and sorry for my english
yannis is offline
Old 08-23-2010 | 05:16 PM
  #1072
Having a puzzling issue with the Reedy. Yesterday I tuned the lsn to what felt right and the hsn was set a bit rich for the day, I went on track and did probably 6 or 7 laps and it was at 325 F Not good, obviously.
So in a roundabout way, is it possible the lsn was too lean and causing the engine to overheat? I'm kinda sure it wasn't the high speed being lean 'cause I was around 4 turns out from bottom, I'm just out of ideas on what it could be.
tromoly is offline
Old 08-23-2010 | 05:22 PM
  #1073
TKO or stock. Spend the little extra on the ceramics
Stirex is offline
Old 08-23-2010 | 05:24 PM
  #1074
Check to see if the HSN is working its was out, I had this problem with mine. Also check for airleaks, tubing, tank etc. This can also make the engine lean out and run higher temps. Or if something is binding and causing the engine to work harder, brakes, diffs, bearings, cvds, etc.
Stirex is offline
Old 08-23-2010 | 05:25 PM
  #1075
Anyword on the release of the 121 ST?
Stirex is offline
Old 08-23-2010 | 08:30 PM
  #1076
Brandon Melton's Avatar
On the wrong type of track a lean LSN and rich HSN will cause the motor to run that hot. Depending on your climate start around flush on the LSN and about 2.5 turns out from closed on the HSN.
Brandon Melton is offline
Old 08-24-2010 | 03:16 PM
  #1077
That's what I thought, thanks for the insight.
tromoly is offline
Old 08-24-2010 | 03:22 PM
  #1078
R/C Tech Elite Member
Since I've reviewed this engine, I still loving it. It runs strong and idles like a charm. Coupled to the 2039 tuned pipe, I have good RPMs and smooth power band.
Sylvain is offline
Old 08-25-2010 | 02:42 AM
  #1079
RUNNINONMT's Avatar
i was looking into getting new bearings, and wanted ceramics but i couldn't get a straight answer. because on the tko site it said that their bearings
were not for use in the reedy. so i just got another set of stock bearings.
RUNNINONMT is offline
Old 08-25-2010 | 06:05 AM
  #1080
Rear Ceramic from AE/Reedy. Check this out.
Boca website says they have a set. Has anyone used it?
