REEDY .21 Nitro Engine
#316
#319
I am really thinking about Switching out the V-spec to the Reedy mill in my RC8... I love my V-spec.. Tons of power and I run it on the rich side and it still has tons of power...
Any opinions on the switch...
Nick
Nick
#321
Agreed, the Reedy has Killer bottom end, as good or better than any other 21 on the market. Lacks a bit on the top end tho, vspec def has more up top. I'd say that the Reedy is potentially the best short track motor available. If you have a medium to large sized track, you may want to get it modded to boost the top end.
#323
Hey i have a few questions about these engines, looking to buy one, however i have a JP-4 pipe and was wondering how these engines run with thiese pipes ?
Also whats the recommended glowplug for these engines, its usuall about 15-25 degrees celcious here, not that humid, i can get ahold of really only OS and RB plugs easily, and maybe novarossi.
Any help would be appreciated, this is to go in a 808 buggy too
#324
#325
And what economy have people been achieving from them ? as when they first got seen there economy wasnt the best, as seen at last years worlds with maifield, however he seems to have better economy now ?
#326
Ok thats good, what about pipe ? will a jp-4 be good ? as its more a mid to top end pipe, so may increase the reedys mid to top while taming its bottom end a tiny bit ?
i'm pretty heavy on the throttle and run it somewhat rich, with the 7mm restrictor and easily get 9 mins in my truggy
#328
We got to race with SPEEDSKI and Nick this weekend in Nashville, TN and had a great time racing and sharing info on the 121VR.
Nick's engine had a little more time than I had gotten on mine and it was settled with the OS 2050 pipe. I believe SPEEDSKI was helping him pit, hardly saw them touch a needle on it.
Myself, I needed to get some more fuel through my REEDY, I think I was at 1/2 gallon on it when we got there. After several tanks of practice and qual's the engine really settled in. Also, I tested an 053 pipe which worked well for me. Once I tuned to the 053 pipe, approached the 1 gallon mark on fuel, the motor came to life.
I ran a 15 min B-main with 1 pit at 7.5 mins no problem. Bumped to the A-main and again pitted at 7.5 min to 8 min easy. Motor never flammed!!
#329
I bought two 121's right when they came out. One about a week before the other one. I ran a gallon of Byrons 30/11 through the first engine and was never happy with its performance. The bottom end performance was killer, but noting up top. I mean, nothing. I ran P3s and P4s with no change in performance, and a 2035 pipe. I had dirt get past my air filter and roughed the crank up a bit. So I put about half a gallon of the same Byrons fuel through the second engine with the same pipe but only running a P4 now. Then went out ran 3 qualifiers and put her through 22min of a 30 main before my receiver pack died. I can honestly say the performance of this second engine is way better than the first. It has the same bottom end snap, but with alot more top end pull. I am only an hour leaner or so on the hsn and maybe 2 hours leaner on the lsn. I really am happy with how its performing. I have a +1 clutch bell I am going to try. If I can soften the bottom a little more and pick up a little bit more topend, I will be real happy.
With the 8mm insert, I can get 9min in a main with no flame out. I think I can push it to 10min once she has a gallon or so through her. The engine is in a D8.
Andy
Andy
#330
Andy
Andy
