REEDY .21 Nitro Engine
Old 04-05-2010 | 09:18 PM
  #871
Jason Pelletier's Avatar
Yep no bs my reedy doesn't need to run hot for power. Hehe it's true !
Jason Pelletier is offline
Old 04-07-2010 | 05:13 AM
  #872
well i went from rb to reedy, rb is just to dam expensive now, but my c6 still kickin after 4 gallons, anyways anyone know the stock settings for low and high needles , wheni got mine, it seems to lean when i started it, if anyone knows a good starting point please let me know please
skidoos is offline
Old 04-07-2010 | 06:10 AM
  #873
cbaranski's Avatar
skidoos,
Try 2 1/2 on the top and 3 1/4 on the bottom
Chuck
cbaranski is offline
Old 04-07-2010 | 07:26 AM
  #874
My out of box setings :
first engine - HSN 3,25 , LSN 4,15
second engine - HSN 3,25 , LSN 3,15
Kubson is offline
Old 04-07-2010 | 08:51 AM
  #875
Midnight's Avatar
There was a guy on here with a good base setting. Would advise not goin off a flush setting. Tried that and that was way off. I would start 3.75 top and bottom and adjust from there.
Midnight is offline
Old 04-07-2010 | 02:29 PM
  #876
ok thanx guys, got an idea at least , its funny the manual doesnt give u a startin point, anyone have eperience with this motor against an rb c6 , bc as of now i own both of them
skidoos is offline
Old 04-07-2010 | 02:49 PM
  #877
Skidoos check your PM's.
Also thought this might be useful for some.
Brandon Melton
Yeah sure thing, you are right, it's often the small stuff and even the simple things can get a engine to run great.
I'll go more in depth how I tune the motor, there are all different ways of how people break it in. This is how I have personally broke in my Reedy engines, and they all tune well and perform for a long period.
-always preheat before starting it up for the first time
-wrap the head with something like foam, foil, a sock or something to retain heat.
-idle just ONE tank through the engine (just to oil and seat the parts). LET COOL after first tank
-PRE HEAT engine again-on the second tank I am running the engine on the ground, with the HSN a little rich for lubrication but lean enough to get temps up to around 240. Run the whole tank out using idle to 1/2 throttle bursts. let cool again
-Keep doing this for 3 tanks, then for tanks 5-8 I keep it at the same HSN setting but now I am making about 100ft pulls of wide open throttle (temps still staying around 240).
-after 8 tanks I put a race tune on it and try to kick some butt
-biggest thing is making sure the engine cools after each tank, and then preheating it before the next start up. I usually preheat the engine for the first 1/2 gallon.
TUNING
I will say that on all 5 engines I have ran, I have never used a carb or back plate sealant, and have never had an air leak or funny tuning. Some people swear by sealing an engine but I have had good success without doing it.
I actually prefer to tune from the bottom end first, and can usually get it really close on the box before hitting the track. Here's how I go about a tune when I get to the track.
1.) Start engine and rev gently for about 2 minutes to get some heat into the engine, always tune the engine when up to close operating temp.
2.) I clear the engine out when a couple solid (not death revving) revs then listen to how it comes down to idle, wait about 5 seconds and hit the throttle.
3.) I look for a steady smoke trail and a steady clean pull from the bottom end. You don't want heavy smoke at first tapering into a faint trail. The engine shouldn't hesitate with a rich or lean bog. Should have a crisp sound with steady smoke.
4.) If the engine blows lots of smoke and hesistates to start pulling, lean the bottom end until you get what’s described above. If the engine doesn't blow smoke and stutters to accelerate, richen the LSN until the desired setting.
5.) A KEY indicator of having a close tune on the LSN is listening to the engine come from a rev back to idle. With the proper glow plug and a properly tuned LSN, the engine should almost immeditaly achieve idle speed after a rev on the starter box or on the track. If the idle hangs up, then slowly comes back to idle in "steps" you are too rich on the LSN, probably noticing a lot of smoke as described above. If the engine tends to run on and maintain a high pace without ever coming back down, the LSN is too lean. ALL THIS IS ASSUMING THE IDLE GAP IS SET CORRECTLY (which is around .6-.7mm.)
6.) Once the LSN is where I want it, I will tune the HSN on the track. Assuming climate hasn't changed dramatically since the last time I raced, this is usually only 1 hr. either leaning or richening for optimal tune. If it's the first time with a new engine, it may take a couple adjustments to hit correctly. A proper tune on the HSN should pull hard until the end of the longest straight, but never totally run out of smoke or "run on" at the end of the straight. If you have properly set the LSN and the engine runs on after long straights, the HSN is too lean. If you see a little smoke, and it doesn't run on, you are very close.
7.) After break in, if the engine runs and performs well, and all driving characteristics are as they should be, I don't pay attention to temps anymore. If you have it tuned properly, the temps will fall where they should. You will learn to trust your tune. I could just about tell you within 5 degrees what it would be before a pit guy checked it, LOL.
8.) After setting the HSN on the track, I will then just double check the LSN sound and response after a tank run before shutting it off after it's at full operating temp. Make any minor (if needed) adjustments, and then it's usually good for the rest of the day, unless the mains go into night fall.
Chris Reilly is offline
Old 04-07-2010 | 03:01 PM
  #878
ok got everything, on my 6 tanks 4 more to go before i race tune it, i give u my feed back versus my c6
skidoos is offline
Old 04-07-2010 | 03:08 PM
  #879
You might be able to gear up 1 tooth on the clutch bell as well.
Old 04-07-2010 | 03:11 PM
  #880
i heard about this, why is that?
skidoos is offline
Old 04-07-2010 | 03:15 PM
  #881
Apparently it has great bottom end. Mine is still NIB till I get home.
Old 04-07-2010 | 03:20 PM
  #882
ok i try it out on 13 first
skidoos is offline
Old 04-08-2010 | 12:45 PM
  #883
i read earlier in this forum, that the crank with the black insert in the crank is a bad one, is this true and what do i do? so far the motor runs good, havent tried it at a track yet, just breakin it in, but i do notice eractic idle at times
skidoos is offline
Old 04-08-2010 | 12:49 PM
  #884
Charles Godwin's Avatar
What do you meen by 'erratic' ? I think AE/Reedy (not 100% sure) actually replaced the cranks if you had the ones with the black putty insert. Best to check with AE.
Charles Godwin is offline
Old 04-08-2010 | 01:06 PM
  #885
sometimes it idles high then low , but still new, only have 8 tanks on it now
skidoos is offline
