REEDY .21 Nitro Engine
#886
I have yet to see anything but a black putty. I got a new engine straight from AE on there last shippment and it had black putty. I have never had one come out but I know someone that had it happen and they cleaned the engine out and is running it without the putty and it runs fine.
#889
Its normal for a LHS to tell you to run a P3, a lot of other engine run their best with a P3. For the the Reedy it likes the P4, RT4 and OD97T. I normally run the OD97T, its better than the P4 for me. Also the OS plugs and Reedy plugs are the same.
#890
A little update, I've got about 2 gallons on my reedy in my buggy, put the extra shim under the head and took the other 2 out, all I can say is holey hell!
This thing is so fast I cant stop in time for the corner, I'm hooked, will never buy another motor again.
Hey joey, I totally forgot to look you up at silverstate, How'd you do?
#891
Hi guys - I plan to run my new Reedy on 25% Nitrox fuel - do I have to put in the extra shim that came in the box?
Also, I just read the "break in bible" thread is this the best way to break this engine in? Or is the "old school method" better?
Thanks......
Thanks......
#892
You'll be fine with the shimming that's already in the engine for the 25%. Once you get her broken in, then you could remove the shims that were installed in the engine and then install the one that was extra in the box. And you'll be good to go. That's what I was told and I'm just passing on the knowledge.
#893
Doesn't she look pretty. I like how the blue flows
Only gotten to run a couple tanks through it before I started having issues with the rtr box. Probably going to get a ofna truggy box for this beast
#895
As for the setups, I ran my Leisure Hours outdoor setup the fist round. Shane's setup the second round, was good but I broke a shock end. Third round and the main I ran Cav's setup. Which I don't know if it has been posted yet.
#896
My 3rd round of qualifying was my best run, I was 4th fastest over all. Having 14 minutes of practice time to get used to the outdoors again was a little tough and also trying to adjust the car for the track. My first two rounds I was 28, 25 and the 3rd giving me that 4th, placed me 4th in the B. I jumped out early but after getting hit in the HSN, it broke off. It was a hard hit, so I cant say the Reedy was weak by any means. I had a great time and will be out there next year also.
That's bogus though I hate when collisions mess my junk up. I feel for you....was that HSN sealed ????
#897
#898
ok guys just finished breakin in my motor, i am runnin 30 percent, and i just read i should take out, the shims and put the one that came with it, even on 30 percent, and i did noticed, it doesnt have that much top end compared to my rb c6, now i been told to go to a 14 tooth clutch bell, in losi 2.0, is this true??
#899
I've not ran mine in a race yet its still really new, so its still getting broke in but I'm running the 13t in my losi 2.0
