Like Tree2Likes
GRP... Engine... Thread...
Old 08-05-2009 | 11:12 AM
  #1726
8&stuff's Avatar
on the 3 grps i ran through the past year alls i used was odo plugs. coming from you il take the word as the gospel. i never had a leak and everything i ran, of which were rebuilds that had good lifespan. but i also have to say that i was told not to run os plugs in jammin jpx engines and have been doing so with great success. in my area everybody has ran the same odo plugs as i have...exept for 1 out of a good dozen that i know that ran an os p3(only 1 grp ran on os and was fine). im not about to argue with mr. losi...no doubt....considering youv ran grp longer than i have..i am waliking away with your word!...its all just a shame that grp has dwindled into what it has....
8&stuff is offline
Old 08-05-2009 | 11:20 AM
  #1727
Matt M.'s Avatar
Administrator
the od plug worked one just had to make sure it was properly snugged...
it is a shame that a good motor has been brought down....i have 3 of them along with a spare rod and piston/sleavenot sure how much longer i will keep them, but they are not worth anything so, i will just burn em down, and get something else...
Matt M. is offline
Old 08-05-2009 | 11:25 AM
  #1728
8&stuff's Avatar
im still using 2 of my grp buttons. and now that you got me wondering they do seem a little over snug with the odo plug. the one last turn is a little over snug, almost squeeks lol..so i have to agree with you.
8&stuff is offline
Old 08-05-2009 | 02:03 PM
  #1729
air8's Avatar
To add to CasyP's response--Geo, or another user, measured the taper angle of the ODO plugs. The ODO plugs had a slightly different taper. Those guys suggested to keep using the same brand of plug, which ever that may be, that has been used in the engine previously. Switching back and forth from ODO to GRP/O.S. is where the leak-by came from. They mentioned the taper creates the fit and seal. If you use the different taper then it won't seal properly.
Someone correct me if I'm wrong here. But that's my recollection of the previous discussion regarding the turbo plugs.
air8 is offline
Old 08-05-2009 | 02:44 PM
  #1730
Matt M.'s Avatar
Administrator
this would be correct, i always use os plugs, and tried a od.....it was as 8 said....it was tight on the last turn, and squeaked.....if you didnt do that it would leak..
i willl put a grp plug in and see how it is...
Matt M. is offline
Old 08-05-2009 | 03:22 PM
  #1731
8&stuff's Avatar
I appreciate the clarification. although im not running grp im still using there head buttons...
8&stuff is offline
Old 08-05-2009 | 05:48 PM
  #1732
Timmo's Avatar
The question is,will someone find a replacement con rod .
Timmo is offline
Old 08-05-2009 | 05:52 PM
  #1733
i confirmed with nitro house today that they have one of these in stock
http://www.nitrohouse.com/catalog/pr...ducts_id=16760
let the feeding frenzy commence
zixxer is offline
Old 08-05-2009 | 06:56 PM
  #1734
mblgjr's Avatar
No; they should not.
It's supposed to be sitting in a certain someone's desk drawer with my name on it since Fri or Mon; don't recall which day I talked to 'em.
Seriously...Not joking at all. Though it's not out of the system, they shouldn't be able to actually find it when they go look for it.
mblgjr is offline
Old 08-05-2009 | 08:23 PM
  #1735
8&stuff's Avatar
omg what a find!
8&stuff is offline
Old 08-06-2009 | 12:01 AM
  #1736
Timmo's Avatar
Unbelievable..
Timmo is offline
Old 08-06-2009 | 05:37 PM
  #1737
i felt sooooooooooooo bad about the wrong r7 rod info ....and yeh mlgr is right because it didnt come up in their in engine parts area .....came up on a google search under the part number ....goes to show you cant always believe what you here about compatibility ...ive got a standard that needs a rod ...hell with it i will run my other 2 grps that are doing great ....i would a got it if id had 50 bucks
zixxer is offline
Old 08-07-2009 | 08:02 PM
  #1738
mblgjr's Avatar
If anyone *has* to have it it is for sale
For ONE MIIIIIIILLLLLLION DOllarz...
mblgjr is offline
Old 08-09-2009 | 09:25 PM
  #1739
Cory Kerber's Avatar
Just bought a used Tuned. Going to run it with my JP-2.
Hopefully get a good 3-4 gallons out of it. (It's got about 10 gallons total on it, and was just pinched. )
Cory Kerber is offline
Old 08-09-2009 | 09:31 PM
  #1740
Integra's Avatar
i would be worries about the rod.
Integra is offline
