GRP... Engine... Thread...
#226
Guys,
I see that many of you are using the OS P3 plugs. I have also read that some of you think the P3 improves idle ?
For me in the UK P3's are probably more expensive to get than GRP/NINJA plugs,but if the motor proforms better for them, then I'll get some.
Just curious as to wether It's really worth my while trying P3's or I'm as well sticking with original plugs.......
Cheers
Rod
Cheers
Rod
#227
Screff - my initial thoughts on the GRP compared to other mills I have owned and ran recently are as follows:
Ninja B01A - GRP seems to have more top end, but the powerband is very linear just like the Ninja was
Nova 21-5kt - 21-5kt seems to hit harder low and mid range, but does not have near the top end the GRP has. The Nova is much more finicky to tune as well
Max Power M5 - the Max Power was like the Ninja B01A, except more power everywhere...the M5 and the GRP will likely be pretty close (which is great imo, as the M5 was my favorite engine I have run on the track)
I need more fuel through the GRP, as I have only raced it one day, but from what I have seen, it is reliable, stable, very smooth power, great runtimes, and should last a good while. I do not think it is the most powerful motor out there, but that is not what I need on the track
#228
From: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Matt, have ya had the chance to compare the GRP to another motor - power wise? I'm curious to see how it matches against my EB Modded V Spec. I'll be starting break in on my GRP tomorrow when the engine mounts come in.
And I love that sig. Ironically, I got yelled at on the driver stand this past Sunday when I was lapping a guy in the main for the 4th time. He yelled at ME to get out of the way!
#229
#231
Bread,
Thanks for that, a hotter plug usually helps iron out an idle, But to be honest mine is pretty good using the No.6 . I may try a No.5 just to see how it likes it. But I'm using Gen2 30% and the std. shimming so currently things are good as is.
If you guys are using the OS simply because of cost I'll happily continue with Ninja'
Cheers for the reply
Rod
Rod
#233
Hey Guys,
Has anyone try to put the GRP on the losi buggy with the losi quick change motor mount? I just try it and it seems like the bottom of the case is to large. The case is hitting the side of the mount. So do I have to go back to the stock ones or is there a mod?
Thanks,
Thanks,
#235
#237
Hey Guys,
I have some more questions. When you open up the carb barrel all the way is the needle in the carb half way out? Why I'm asking is that my V-Spec never comes all the way out.
My needle setting are
HSN - 3 3/4 turns out
LSN - 5 1/2 turns out
Is this the factory needle settings for this motor? Also I just got done breaking my motor in on a break in stand and will hit the track Friday.
Thanks for your help.
Ed
Ed
#239
Well I popped my GRP in the new 808! I will see how it runs tomorrow in this buggy. These GRP's are quality motors, but defiantly not an RB C6BBT7 when it comes to power. My C6's will blow the doors of the GRP from bottom to top.... however the saying "slower is faster" is probably true. So I'm hoping this is a good combo for race day. Might run this at the Nationals....
2Likes
