Like Tree2Likes
Go-Tech Engines Thread
Old 02-10-2013 | 12:40 AM
  #14341
Well crap and your right I have missed the curve here, the go engines are just so dang sexy, my problem with the major brands is just that, they're big and there isn't a single guy running a go here in Hawaii. All the OS and Nova fanboys and I hate it...
smoothcriminal7 is offline
Old 02-10-2013 | 12:54 AM
  #14342
Well crap, I guess I missed the curve with go, I just have an issue with the big names because that's all ppl run here. OS and Nova families or it is automatically crap. I have been running an ofna 8 port with some success and its barely got any pinch... I guess ill pull out the RB if this 3 port swap doesn't work...
Old 02-14-2013 | 09:17 AM
  #14343
Default Go .18 Nitro
Anyone know where I can get a conrod for a Go.18 engine?
marknekrews is offline
Old 02-19-2013 | 10:40 PM
  #14344
MAGPIE-121's Avatar
you'll have to shoot the factory an email & they'll put u on the right path mark
MAGPIE-121 is offline
Old 03-16-2013 | 09:47 AM
  #14345
invrtd's Avatar
Please don't kill me if I someone already asked, but I did try the search function on this thread. I need 3 needle carb settings. I purchase a fresh pinched gxii and have it broken in but mid range needle had been removed during rebuild by previous owner. Have about 5 tanks thru engine at 180-240 degrees varying temps to cycle heat. I can not get engine past mid range point without quitting. I have the hs needle in about 1-1.5 turns in from flush and I have gone the other way too with the HS needle. It doesn't seem to matter what I do, it wont get passed a mid range throttle point. I think the mid range needle might be the issue. I am not a supper nitro buggy guy. Really experienced with heli motors with rings and 3 needle carbs. Hate asking for help, but need it!
invrtd is offline
Old 03-16-2013 | 09:51 AM
  #14346
Anybody ever run one of those cheap 5-ports that were being sold off by Amain (for like a 100 bucks ) last year?
Herrsavage is offline
Old 03-16-2013 | 01:17 PM
  #14347
motomatt's Avatar
The mid-range "needle" factory setting is flush with the housing.
motomatt is offline
Old 03-16-2013 | 05:49 PM
  #14348
CHOAS's Avatar
Hey guys,
I need the correct head shim thickness for the GX5 and GX7 for 25% nitro.I am not sure if I pulled the break in shim or one thats suppose to be in there.Any help ASAP would be Awsome!
CHOAS is offline
Old 03-16-2013 | 05:50 PM
  #14349
CHOAS's Avatar
Factory 3 needle and 2 needle carb settings would be great too
CHOAS is offline
Old 03-16-2013 | 07:24 PM
  #14350
sriley's Avatar
Ed,
Try this link.
http://www.go-racing.co.nz/
sriley is offline
Old 03-17-2013 | 10:01 AM
  #14351
G5T?
I kick myself once a week for not picking one up. I'm still running my gx5r, the older version of the motor.
AZTman is offline
Old 03-17-2013 | 10:09 AM
  #14352
Originally Posted by AZTman
G5T?
They're on offer here, including pipe, for like €130 - crazy good deal.. I just have too many engines as is at the moment unfortunately.. I always had great luck with Go's.
Keen to know how it compares to the GX-5R (which I also had - was great..)
Old 03-17-2013 | 04:48 PM
  #14353
Rsickles's Avatar
Updated GX-5R, basically Precirotate D5. Believe the timing/porting/etc is identical, it's just the TiN crank, revised cooling head (that hopefully doesn't break fins), and maybe other couple odds. Performance is probably pretty much same thing.
A racer here bought the G5T for his GT8 car since it was so cheap. Seems to be a good enough mill. About what you'd expect if you're familiar with GO engines.
I regret not buying a G5T when A-Main was clearing them out, because A Main eventually started blowing out GO parts (again )... Con rods were are $11, entire 3-needle carbs for $25, P/S sets $40 or $60 for GXII version, wrist pins $.50, crank cases for $25, cranks for $20, back plates for $3, head buttons for $4, etc. Could have bought a ton of spares.
Rsickles is offline
Old 03-18-2013 | 04:37 AM
  #14354
invrtd's Avatar
Saw a couple of pics of the carb online and set the mid range needle flush like mentioned. Bought the motor used from local driver with new bearing and a pinch. However motor case was cracked. Amain order on the way. What's the link for the company selling the motors for 130eu.
invrtd is offline
Old 03-18-2013 | 09:20 AM
  #14355
hi all, i tried searching around on here but couldnt find a clear answer, i am trying to find a backplate for the .25 3 port sport motor, it has a pullstart on it and i want to replace that, any info is much appreciated.
hayes371 is offline
