Go-Tech Engines Thread
#6842
#6843
Even with the extra shim on? I wasnt able to at first, but now its much easier, I mean , it doesnt just roll over, but it doesnt take too much pressure to turn it over the TDC by hand. And realize too, that I still have the flywheel on, so its not like I'm turning the crank over with my fingers ,LOL
#6844
#6845
#6849
I just put that up for a comparison. I would highly recommend getting a hold of mark at massive mods, or 22racer sells here in the states also. by the looks of the kit the gent from Alaska is posting looked like one advertised on massive mods sight. But I think they are out of them,not sure though. The reason I am posting this info is warranty issues. If your not concerned about warranty, well you know where to go.
#6850
Check the wristpin clip scenario like Matt says. If thats not it, something has gone wrong or something has been done wrong for it to loose it's pinch that quick. We are not kidding when we say these engines are super tight. If you pardon the pun, you may have a sick puppy on your hands Mr Sick puppy
#6852
#6853
Nope - no way you should be able to turn that motor over after 4 tanks - NO WAY !!! It should still be jamming your starter box solid after 10 or 15 tanks without a heat up first.
#6854
You should never try to turn the motor over by hand especially when cold
if for some reason you want to check pinch before fully broken in find bottom dead center and turn flywheel slow when u meet resistance STOP!!! That’s how u can track the motors full break'n progress after initial break in ...every 5 tanks or so u should be able to turn fly wheel a LITTLE bit more each time u check.....
never never never ever force a cold motor over or even a warm one...just my opinion...im no guru
2Likes
