Go-Tech Engines Thread
Yeh I'm thinking the base will be fine but that adapter looks like a 10mm nut and the ascendancy is an 8mm to give clearance for a socket to tighten it up..I'm not sure there will be enough clearance between the nut and the clutch to fit any socket..but maybe an old style box spanner will fit..Oddly enough I thought I had a similar adapter somewhere but with a c clip not a threaded hole for a bolt..it was left over from a VERY old car..when I started buggy racing all engines used that kind of adapter...way cheaper to replace than a crank if you kill a set of clutch bearings.
Hi Gizz, I think that nut might be a little big to fit down inside the retaining collar of the Ascendancy unit. I have some of the adaptors on the way down to me from A-Main, so should have them in around 4 - 5 days. I will check it all out and let you know if it will work asap.
Hey, how is the 2047 pipe? I picked one up by chance recently.. Have a Go GXR 5-port and a Mach I'd like to try it on.. Is it more low end, top, mid, lame, great, or what? Thanks... Right now I want to try it in my SC8 with both the Go and the Mach..
im not familar with that pipe, all you can do is give it a try and let us know. watch your temps, some pipes seem to make engines run hoter than normal.
the 2047 was before the 0801 and now we have the 2072..guys used to run the 2047 pipe with 0801 header or other way around (I'm not sure now) to get the same results as the new 2072.
oh to answer your question, it was a very smooth pipe rite through the rev range.
Yep, the old GO 2047 is a nice pipe. Like Flanno said, very smooth. Basically a mid to top end pipe - it has a shorter header than the 0801 or 2072.
We used to use the 2047 with the longer 0801 header - we called it the poor man´s 2072 in those days
. That is a really nice combination and will work awesome on the GX-5R. It will work great with the standard header too, bit if you can get hold of a longer header use one.
I still have my ¨poor man´s 2072¨. I use it for breaking in motors now as it is a bit clogged up from lots of use over the last couple of years.
. That is a really nice combination and will work awesome on the GX-5R. It will work great with the standard header too, bit if you can get hold of a longer header use one.I still have my ¨poor man´s 2072¨. I use it for breaking in motors now as it is a bit clogged up from lots of use over the last couple of years.
Thanks Grizz
Glad to see my memory isn't totally gone in my old age
So it was the 2047 pipe and 0801 header
PS; I ran the Truggy Team Spec today..............It's totally insane, running 14/46 gearing I still had to put 0.9mm springs in it to keep the front down. Big Grin
If funds are not an issue, then purchase an MG66 - even better mid - top
2Likes
