Like Tree2Likes
Go-Tech Engines Thread
Old 04-05-2011 | 02:03 PM
  #13666
Well first off no apologies needed for jumping in to this forum. Feel free to come in and ask any question you need to.
As for the pipes. The 2072 has been the best all around pipe i have used on the GX7. The JP4 also worked pretty well and so did the 2013. However on a tight astroturf track I would probably go with the 053. It will get you on the pipe (lots of bottom) quicker than any of the others I mentioned and still not lose to much top.
matrixmike28 is offline
Old 04-05-2011 | 04:44 PM
  #13667
Flanno's Avatar
Originally Posted by Gizmatron
man Flanno ..never leave the crappy std on/off switch in they always fail..I don't much like the futaba plug your using either..try tamiya plugs..not a lot bigger than the futaba but much larger pin contact area for a better connection and a clip to lock the two halves together..
The female is from team magic, It is quite a tight fit, very hard to get the male in and out so shouldn't come undone.
Flanno is offline
Old 04-05-2011 | 04:46 PM
  #13668
Flanno's Avatar
Originally Posted by rider313
I use protect JST conectors. They are compact and can handle some current plus they can handle being plugged in and unplugged all the time.
On an engine note. It that the Go 2072 pipe your going to be running on that .25? My RW mods .25 6 port loved that pipe. Maybe Godzilla will like it to.
Yep it's a 2072
Flanno is offline
Old 04-06-2011 | 05:30 PM
  #13669
Flanno's Avatar
OK, for you Mugen and X ray guys, not sure if will work for other brands, you will have to test for yourselves.
If you have a realy worn crank shaft end from your clutch bearings and don't want to replace the whole crank, here is a cheeper alternative.
Remove all clutch assembly,
get out your dremel cutting wheel and cut off the clutch shaft just in front of the clutch nut thread,
and replace with these below;
http://www.amainhobbies.com/product_...Hex-Screw-Full
and
http://www.go-engine.com/pdt_view2.a...area=15&cat=28
I don't have a GO flywheel, but I use
http://answer-rcusa.com/zencart/inde...roducts_id=358
Flanno is offline
Old 04-06-2011 | 08:27 PM
  #13670
grizz1's Avatar
and
Nice one Flanno I will get a few of those in for the boys with some wear on their GX and MG cranks. I have the anodised alloy GO flywheels in stock already. Very popular too I might add. They match especially well with the anodised bits on the new GXII's - very BLING !!
grizz1 is offline
Old 04-07-2011 | 02:24 AM
  #13671
Flanno's Avatar
Put some tanks throu the Truggy Team Spec today
Flanno is offline
Old 04-07-2011 | 02:31 AM
  #13672
When are these things going to be available in Europe(including the clutch)?
And will an older version Go conrod work? I have a new Caster conrod and front-bearing is why I ask.. Might be more inclined to get a new engine I already have parts for...
Herrsavage is offline
Old 04-07-2011 | 02:36 AM
  #13673
grizz1's Avatar
Are you refering to the GXII motor ?
grizz1 is offline
Old 04-07-2011 | 02:38 AM
  #13674
Yeah...
Have seen the Argus for ex, and the new silver Alpha, popping up here and there, but not the new Go's.. Also, the older Go's have been on sale a lot recently..
Old 04-07-2011 | 02:42 AM
  #13675
they havent landed in the UK yet either as far as i know,i only have my pre-production one..problem in the uk is they always get stuck in customs.
fastboy is offline
Old 04-07-2011 | 03:43 AM
  #13676
grizz1's Avatar
There was a hold up with the new GXII packaging. They would have shipped out from the factory last Friday or early this week, so you should start to see them in a few days (like you say, depending on good old customs).
grizz1 is offline
Old 04-07-2011 | 06:56 AM
  #13677
Flanno's Avatar
and
Flanno is offline
Old 04-08-2011 | 01:39 AM
  #13678
Gizmatron's Avatar
Hey Flanno...is that ofna nut assembly small enough to fit the JVD/Ascendancy racing clutch? Grizz1 can you try it and see as I have at least 1 MG66 crank with that kind of wear on the end..be nice to reuse it.
Gizmatron is offline
Old 04-08-2011 | 02:13 AM
  #13679
grizz1's Avatar
Hi Gizz, I think that nut might be a little big to fit down inside the retaining collar of the Ascendancy unit. I have some of the adaptors on the way down to me from A-Main, so should have them in around 4 - 5 days. I will check it all out and let you know if it will work asap.
grizz1 is offline
Old 04-08-2011 | 02:21 AM
  #13680
Flanno's Avatar
Good one Grizz, I don't have adsendancy to try.
Flanno is offline
