Like Tree2Likes
Go-Tech Engines Thread
Old 04-03-2011 | 02:18 PM
  #13636
Suspended
Originally Posted by LOSI123
im after a bargin,
could the 5 port with the combo pipe get 10mins in a buggy?
if drive smooth, and tuned well etc etc...?.
YEP, also remember the lower the nitro content the better the milage
inferno13 is offline
Old 04-03-2011 | 02:31 PM
  #13637
bigmatt's Avatar
? I thought it was the other way around. I have a problem with the savox servos glitching bad/one stuck wide open even with fail safe. you ever have any trouble? We are running same radio gear, I am using lipo with losi regulator. 1257's
bigmatt is offline
Old 04-03-2011 | 05:32 PM
  #13638
Flanno's Avatar
im after a bargin,
yes
Flanno is offline
Old 04-03-2011 | 05:36 PM
  #13639
Suspended
i run the 1267 and 1268 with lipo without regulator, ive never had a problem, YET (now i will)
Old 04-03-2011 | 07:43 PM
  #13640
ecko''s Avatar
temp???? im not tunning by temp but ive noticed my gx5r runs best at 250-260 any one now if it should be that hot?
ecko' is offline
Old 04-03-2011 | 07:47 PM
  #13641
Suspended
do you have a steady stream of smoke comeing out of pipe? if so, no worries. if not richen it up a smigit, mine runs about 240-245 (after 15 min hard run) and runs awsome!
Old 04-03-2011 | 07:54 PM
  #13642
motomatt's Avatar
My GX5R ran 275F at X-fest. ran flawlessly.
motomatt is offline
Old 04-03-2011 | 08:00 PM
  #13643
Suspended
right on, temp not really a issue with these as long as you are getting a steady stream of smoke out of exhaust! (unless you flip it over on the lid and runs wide open for 20 seconds and stretches conrod and discolors bottom of cooling head....LMAO) been there done that
Old 04-03-2011 | 08:01 PM
  #13644
motomatt's Avatar
Alcohol is the "fuel" in your jug of fuel.
Add oxygen and heat...............you get combustion.
A gallon of 30% nitro with 10% oil has 76.8 ounces of alcohol.
A gallon of 20% nitro with 10% oil has 89.6 ounces of alcohol.
That's a 16% increase in alcohol.
Moto
motomatt is offline
Old 04-03-2011 | 08:03 PM
  #13645
Suspended
Moto
yep, thats what i thought! i use 20% now and get them on run time everytime!
30%= better performance
20%=longer runtime, cooler running
Old 04-03-2011 | 09:36 PM
  #13646
Redvet79's Avatar
Well got my mg66 back from Rex (RW Modding) the other day and ran it today for the first time. Ran it around slow for 3 tanks only because it still had a good bit of mech pinch. Then started to lean it out. The Rex magic started to come to life after 6 complete tanks still just a tad rich temp 245 good smoke it was HOOKED UP pulling front wheels about 1" at the start of the straightaways.
13min run time with more in the bank.
I'll tell you what i am super happy. Running mbx6t 13t pinion 44t spur and plenty of bottom end. Novarossi ceramic bearings front and rear.
Thank You Rex
And Thanks to Bigmatt for the referral.
I also turned down some parts and replaced some.
Rotating Mass
Before After
Conical Diff Gear X2 44g 34g
Front Rear Outdrives X4 36g 24g
Center Diff Outdrives X2 20g 14g
Steel To Alum Axel Shaft X4 36g 16g
Drive Shaft Joint Cup Alum X2 20g 6g
Plastic Spur Gear 44t 30g 12g
7075 Alum Screws Diff & Spur X12 6g 2g
Total Grams 192g 108g
Saved Grams 84g
Saved Oz 3oz
Redvet79 is offline
Old 04-04-2011 | 07:35 AM
  #13647
Ruune's Avatar
Awesome... can you post up some sleeve and crank pics? I'd like to see Rex's magic on the MG66.
Ruune is offline
Old 04-04-2011 | 07:37 AM
  #13648
Ruune's Avatar
also... consider using the long GX LSN or the silver LSN from the GXII.
Ruune is offline
Old 04-04-2011 | 07:40 AM
  #13649
Suspended
where has deadmancourt been?? is he ok?
Old 04-04-2011 | 07:46 AM
  #13650
Suspended
i have one but havent stuck it in yet, is the setting flush?
