Like Tree2Likes
Go-Tech Engines Thread
Old 12-14-2010 | 08:32 AM
  #13126
69mustangbjs's Avatar
nice!
69mustangbjs is offline
Old 12-14-2010 | 01:21 PM
  #13127
MAGPIE-121's Avatar
NEW THREAD FOR THE MG66, as the other one was closed : http://www.rctech.net/forum/offroad-...ml#post8342726
MAGPIE-121 is offline
Old 12-14-2010 | 01:38 PM
  #13128
Redvet79's Avatar
Do the GX-3,5 and 7 port all use the same crankcase?
Redvet79 is offline
Old 12-14-2010 | 01:40 PM
  #13129
Suspended
yes sir! i beleive they do
inferno13 is offline
Old 12-14-2010 | 01:51 PM
  #13130
Redvet79's Avatar
The JB weld is giving out on my GX-7R from a snapped con rod. But got me threw till the end of season.
Redvet79 is offline
Old 12-14-2010 | 01:53 PM
  #13131
MAGPIE-121's Avatar
GX-3, 5, 7 port & MG66 all use the same crankcase !
Old 12-14-2010 | 01:57 PM
  #13132
deadmancourt's Avatar
just let us know if you need a new case there are alot of guys on here that can help you out...and you might find one cheap on fleebay
deadmancourt is offline
Old 12-16-2010 | 04:48 AM
  #13133
I have an old .21 turbo 5 Ports silver head engine.
Just rebuilt it with a GX7R Cylinder, Piston and Rod.
I need to break in it, and need the factory set up for it.
I canīt download the manual from go engine webpage.
Thanks,
Ale
traxxas.uy is offline
Old 12-16-2010 | 05:55 AM
  #13134
Thanks,
Ale
High speed and low speed needles both flush and idle set at .7mm. You may have to turn your low speed needle in a few hours from flush to keep it running though. Make sure your temps stay above 200 and be patient with your break in. I would recommend changing the front and rear bearing first if you have not already and also check the o rings on the carb needles to make sure they are not deteriorated. Once all of these things are done you should have a motor that will make you very happy.
matrixmike28 is offline
Old 12-16-2010 | 06:00 AM
  #13135
Suspended
also preheat lower part of cooling head to 200 to 220 degrees before starting. heres a link to help...........http://go-racing.vpweb.co.nz/Tech-Tips.html
Old 12-16-2010 | 08:23 AM
  #13136
Ruune's Avatar
Thanks,
Ale
before running, please remove the high speed needle and low speed needle. Inspect the rubber seals and PM me if they are degraded at all.
Ruune is offline
Old 12-16-2010 | 06:32 PM
  #13137
22Racer's Avatar
I saw some pics of the new Go motor, it is better looking than I thought it was going to be.
Rex
22Racer is offline
Old 12-16-2010 | 06:36 PM
  #13138
Rex
yes sir!...2011 is gonna be a great year....
Old 12-16-2010 | 07:44 PM
  #13139
bigmatt's Avatar
well???????????? Lets see a pic!!
bigmatt is offline
Old 12-16-2010 | 09:27 PM
  #13140
grizz1's Avatar
I'm told testing is coming along fine, and the March release date is looking steady at this stage. Maybe even a little earlier if we are lucky.
Sorry Matt. We have been sworn to secrecy, under threat of death
grizz1 is offline
