Like Tree2Likes
Go-Tech Engines Thread
Old 01-13-2008 | 08:09 AM
  #1276
free2day77's Avatar
Originally Posted by g26er
Out of the 086,053 and JP3... which one did you like best w/ the 3 port?
I liked the GO 2047 the best by far. the jp3 gave good power but I lost some runtime. The 086 gave more top end but the mid range suffered a bit.
the GO pipe gave good power all through the power range, from bottom to top and I gained almost 2 min of run time.
free2day77 is offline
Old 01-13-2008 | 03:02 PM
  #1277
Jason Halvorson's Avatar
i have found that the 2047 pipe works very well on all the Go engines i have ran it on, so far ive tried it on the 21-7T, 21-5T and 28-6T...
Jason Halvorson is offline
Old 01-13-2008 | 04:44 PM
  #1278
good luck to all my Go teammates running at the CRCRC!!!!!!!
Old 01-13-2008 | 05:10 PM
  #1279
Originally Posted by bherzog513
Im currently running a picco evo2 and was looking for a cheaper practice motor. How does the 5 port compare(or the 3)?
My lightly modded 3 port sport easily keeps up with the Picco Evo 2's running at my track while still getting 9:20 mins on a buggy tank. $114 plus a $50 mod job = success.
satoch is offline
Old 01-13-2008 | 05:12 PM
  #1280
free2day77's Avatar
shoot, my stock 3prt with the go pipe is flat out awesome.. not much was out running me. I plan on getting a 5 or 7 port for bigger tracks but my 3 port screams right now..
Old 01-13-2008 | 06:35 PM
  #1281
Geo Y-Rock's Avatar
I ran my new 5 port today with an .086 pipe. Nobody had anything over me on the straight and it was great in the infield. Temp was 220. Finished 4th in the A with this bad boy. I'm a believer in these engines!!
Geo Y-Rock is offline
Old 01-13-2008 | 07:21 PM
  #1282
Ultraspeed84's Avatar
how many gallons u guys getting out of the go 7ports and 5ports?? im wanting to buy a new one but im affraid to that i bought a used one then had to put pisto sleeve in it. the gallon later the rod wore out... but not sure how much fuel was through it befor then
Ultraspeed84 is offline
Old 01-13-2008 | 07:34 PM
  #1283
TMizzle's Avatar
cant really judge any product if you buy it used because you have no idea what it has been through.
A brand new GO will last just as long as any other engine u have had, but its not a miracle engine, still have to:
break it in properly
keep it tuned (to rich or lean can hurt an engine)
keep a clean air filter
I guarantee if you do all the above you will get many many gallons out of your GO.
TMizzle is offline
Old 01-14-2008 | 03:39 AM
  #1284
Where can I get the Go 2047 pipe?
pooldoc is offline
Old 01-14-2008 | 04:01 AM
  #1285
vti-chris's Avatar
And of course you need to change the rod as well if you will be changing the piston ands sleeve...in case you didn't do so!!
vti-chris is offline
Old 01-14-2008 | 02:07 PM
  #1286
Russell, Good job puttig the new buggy in the A yesterday. I take it that you must like the new 8.5?
Colin
C Branch is offline
Old 01-14-2008 | 03:22 PM
  #1287
dvp's Avatar
dvp
has other poeple had problems with the carb? new out of the box the high speed and low speed needle turn easy . i have put teflon tape on the theads but still turn easy . motor has a lean bog acts like a air leek. do i need new o rings , also about the head shim mine did not come with one in the box but when i tour into it there was two shims a thin one and one that was about twice as thick.
dvp is offline
Old 01-14-2008 | 03:30 PM
  #1288
dgraham225's Avatar
i just got mine in a week or so ago and the needles are good and tight?
as for the head shims, there should be three shims total, two coppers and an silver shim. only one copper and the silver is installed out of the box, you have to add the copper shim. thats strange that it didnt come with one though? mine come in the box plastic wrapped against a little square of cardboard...
dgraham225 is offline
Old 01-14-2008 | 03:54 PM
  #1289
Russell, what is the thickness of the shim included as mentioned above? My Race 3 port was packed the same way.
satoch is offline
Old 01-14-2008 | 04:58 PM
  #1290
Rocket42's Avatar
Hey Colin thanks man I really like running the Hyper 8.5 it justs suits my driving style. Its great to be back running the car but I still have a few new car bugs to work out of it.
DVP where did you purchase the engine? The older engines came with that setup one .2mm shim and one .1mm shim. It really works fine and my current engine is one out of the same batch. Everything about the engine is the same as the newer batch except the head shimming. You may want to pressure test the carb for the air leak issue. I will shoot you a pm
Satoch the newer versions of the engine include a slightly higher deck ht. This was done to make the engines easier to tune and improve reliability. they feature one .2mm alumn. shim and two .1mms shims.
tmizzle +1
Rocket42 is offline
