Like Tree2Likes
Go-Tech Engines Thread
Old 08-15-2010 | 04:17 PM
  #11461
bigmatt's Avatar
Originally Posted by deadmancourt
well i was running another tank to break in the new motor with the same tune and it start winding out more and more and running GREAT @ 220-230 with the body on i was told it only had 2 quarts through it,which i dont know how many tanks that would be in a losi 8ight truggy and i have put 4 tanks through it myself....i think this motor is starting do drop its nuts and is ready for to take off the some shims!.....so far i have 1 alloy .3mm,1 copper .1mm and 1 copper thats really thin...i run 20%,so what shims should i run now that is broke in?
the 2 copper,are you sure you don't have the .2mm and the .1mm copper shims? I never heard of a .05mm shim.
bigmatt is offline
Old 08-15-2010 | 04:44 PM
  #11462
deadmancourt's Avatar
thats what i meant!...but with the .3mm alloy aswell...now that it is run in what shims should i run?
deadmancourt is offline
Old 08-15-2010 | 04:57 PM
  #11463
grizz1's Avatar
Deadmancourt, I answered that question in full a couple of pages back (post 11445) including a link to an article on the subject.
If you are running only 20%, run 1 x .3mm alloy for max performance and economy. You can add another 1 x .1mm copper for a total of .4 if you like for an added safety factor that will allow you to run 20% or 25% without messing with the shims all the time.
grizz1 is offline
Old 08-15-2010 | 05:01 PM
  #11464
i know i was just seeing if i got a different response but no big deal...i always run LOSI Nitrotane 20% because its easy to get around all the tracks...but was thinking about going to 30% once i go through this gallon that i already have...so i should be fine with just the 1 alloy?....and then when i go to 30% what shims should i add?
Old 08-15-2010 | 05:58 PM
  #11465
bigmatt's Avatar
I myself use 30%byrons with the 2 copper shims.[.2mm-.1mm] I did use the one .3mm shim but quit because they seamed to air leak on me. Now if your going to run 30% it is hard to tell you what shim pack to use. The reason being,how good do you tune? elevation,those sort of things. But mainly your tuning ability. After my engine is broke in I change the rear bearing to ceramic and the rod. Then I set the shim stack and put my needles back to flush. From there I turn the hsn in 1 full turn and leave it. Then I turn the lsn in 1.25 turns,then I check and reset if needed the idle gap. Then it's time to fire it up and get warmed up. At this point I stop using the heating gun to warm the engine and just put a beer coozie over the head. From there it's just touching the lsn 1/16th turn in or out[mostly in] after warm up. The other thing I forgot to mention is before I get this far I use massive mods run in oil in the very first 2 tanks. So as you can see everybody has their own way of doing things.
bigmatt is offline
Old 08-15-2010 | 06:02 PM
  #11466
stupid question , Wheres the best place online to buy???
dan-o is offline
Old 08-15-2010 | 08:01 PM
  #11467
bigmatt's Avatar
amain hobbies, massive mods,answer rc.depends on what your looking for.
bigmatt is offline
Old 08-15-2010 | 09:42 PM
  #11468
grizz1's Avatar
Cool - but please do read the article. It tells you pretty much all you will need to know on shimming the GO motors, as well as plug choice to match which is important.
If your going to 30% I recommend a medium plug like O'Donnell 97T
I currently run 30% with .4mm shim stack and OD 97T and couldn't be happier with the performance and reliability
grizz1 is offline
Old 08-15-2010 | 09:58 PM
  #11469
right now im running .6mm shim stack with 20% and an odonell 77t!...it is still a pretty tight pinchis this a good combo?...i am probally gonna drop to .4mm of shims once the tight pinch settles down
Old 08-16-2010 | 07:50 AM
  #11470
What clutch setup (shoes/spring) do you recommend for Mbx6 and Serpent S811?
Running GX7R and GX5R
Tigergutt is offline
Old 08-16-2010 | 10:09 AM
  #11471
Ruune's Avatar
hey guys... just wanted to let you know that we will have the new clutches and shoes in stock within the next couple of weeks. I'm ordering a large number of these, the 2 in 1 tools, and starter box parts. Plus, we're restocking on head buttons, turbo plugs (lots), plus ceramic bearings.
oddly enough, the new clutch shoes only come with one size spring. I'm told the composite compound we are using works best with this spring. Only time will tell, but I'll be asking for some feedback on here.
New flywheels are dialed. They have cutouts that prevent aluminum shoes from catching when they mushroom after a lot of use. I have one on my MBX6-T and one my agama buggy.
Ruune is offline
Old 08-16-2010 | 04:22 PM
  #11472
Default MG66
Hey guys I just purchased a massive mods MG66. I love this thing it is a beast. I was wondering if anyone might have a suggestion on the best size carb insert to run with the best balance of power and fuel economy?
Loweredram is offline
Old 08-16-2010 | 04:25 PM
  #11473
808gx7r's Avatar
smallest. that thing with a heavy clutch is like a raped ape. its just nuts once you get about a gallon or two through it
808gx7r is offline
Old 08-16-2010 | 04:46 PM
  #11474
grizz1's Avatar
Hi Lowerdam, glad you like the MG66. They are a sweet unit.
Carb restricter really depends on your track type and if your running buggy or truggy.
Once it's fully run in I would start racing with the 7mm. This gives a good balance of power and economy. Most guys in truggy run the 7mm. If you have it in a buggy, try the 7 mm to start with, then if you find you need more run time or it's just too nasty drop to the 6.5. You won't lose much top end at all (and may even pick up a little extra bottom end pull with the smaller restrictor).
Once you have it at race tune for a couple of meetings PM me and we can chat about shimming vs nitro% in the fuel you are using, and how to get a little more run time and power out of your new toy .
Enjoy that puppy
grizz1 is offline
Old 08-16-2010 | 05:05 PM
  #11475
Flanno's Avatar
I agree with Grizz.
7mm in truggy and 6.5 in buggy.
See the GO thread in the Aussie section of mine with a 7mm, 0.4 shim stack, 2072 pipe on C2AMainBlueDot25%.
Flanno is offline
