Like Tree2Likes
Go-Tech Engines Thread
Old 12-30-2007 | 10:23 PM
  #1036
grizz1's Avatar
RETRO RC, Tried that pipe on Sunday. Not discernably better than the Dynamite 086 I have fitted. Seeing I already have the Dynamite I don't think the extra expense of a new 2047 would be warranted at my current level of racing I will spend the equivalent amount on beefing up my XUT a bit more for next season with some of the new "Team Kit" parts from the Bandit.
I will drop that pipe off at the shop on Friday. Thanks for the use of it buddy
grizz1 is offline
Old 12-31-2007 | 05:14 PM
  #1037
Hey guys going to order here in a couple of minutes and was re making sure that i have everything i need
2 x OSM71641300 O.S. P3 Turbo Glow Plug "Ultra Hot" $17.98
1 x PTK-MR105-2RS ProTek R/C 5x10x4mm rubber sealed "Speed" 1/8 clutch bearings (10) $9.99
1 x DYNP5005 Dynamite Platinum 1/8 086 High Speed Inline Exhaust System (Hard Anodized) $49.99
1 x MUGB0509 Mugen Setting Driver For Engine $7.75
1 x JRPSZ650 JR Z650M High Torque Metal Gear Servo $49.99
1 x HBS62510 Hot Bodies Glow Plug & Wheel Wrench $4.89
1 x DYN2536 Dynamite Machined Aluminum JR, Airtronics, KO Servo Horn (Red) $5.25
1 x GMK-0105 GMK Supply "DustBusters" - .21+ Engine Carburetor, Exhaust and Fuel Inlet Caps $1.89
1 x OFN10161 OFNA Quick Fill 500c Fuel Bottle with Auto Stop $7.75
1 x RCE3002 Racers Edge Modified Bearing Oil $3.39
1 x GOTR215PT Go Technology .21 5 Port Race Engine (Turbo Plug) $209.99
1 x RCE10172B Racers Edge 3.5cc/.21 Manifold Seal Blue (2) $4.69
1 x FLZ3015 Fluidz "Filter-Oil" Foam Air Filter Oil Treatment $4.29
1 x PAAPT31 Pacer After Run Oil (1oz) $3.89
GRudinger is offline
Old 12-31-2007 | 05:58 PM
  #1038
I would get rid of that cheap servo and get an Ace Digital DS1015.
satoch is offline
Old 12-31-2007 | 06:02 PM
  #1039
ohh trust me i would if i had the money!!
Old 12-31-2007 | 06:23 PM
  #1040
dgraham225's Avatar
carolinas has that dynamite o86 pipe in the clearance section for $39.99? thats about all i have to offer, lol!
dgraham225 is offline
Old 12-31-2007 | 07:34 PM
  #1041
Rocket42's Avatar
Don't buy the after run oil, you can get some marvel mystery oil from the hardware store that will last much longer. Also i would stay away from the alumn. servo horn. Alumn. servo horns and alumn. geared servo's never match up because of tolerances and over time it will develop a lot of slop. Also buy the o'donnel 77t plugs instead, after doing that you may be able to save up and get a better servo.
Rocket42 is offline
Old 12-31-2007 | 09:12 PM
  #1042
Thanks i already made the order but ohh well.
sweet i already have a brand new jug of marvel mystery oil.
will the servo work ok?
Old 12-31-2007 | 09:14 PM
  #1043
Swede#1's Avatar
I was just about to order a turbo button and Os p3 plugs for my Go .21 when i saw your post and just wanted to know if you recomend the O'donnel plugs just because of cost or performance ? And also, im thinking about getting the GO .25 6p for my next truggy, is that a good choice or should i just stick with the .21 ?
Swede#1 is offline
Old 12-31-2007 | 09:23 PM
  #1044
yea definatly save your $$ and get the Ace RC for steering you ll save your self money on replacing the one you ve got on your list when it breaks, 12.5kg of torque will do very well and last much longer.
DirtRacer is offline
Old 12-31-2007 | 10:08 PM
  #1045
yep he recommends the P3 and the 77t if your on a budget.
Old 01-01-2008 | 12:10 AM
  #1046
In regards to the truggy engine, I think the .25 will be an excellent choice. I'm using a .28 in my truggy with a dynamite 086 pipe and it's a power house. When it dies I will be replacing it with the .25 for sure. A little less power can't hurt, if anything it might be easier to drive...and the extra fuel efficiency from having less overall displacement also can't hurt. I haven't really messed with any carb inserts yet but if somehow I can get 8+ minutes out of the .28 and find a good clutch setup and the right spur/clutch bell combination I may end up with another .28 when this .28 dies but otherwise I think the .25 will be an awesome engine.
It is argued by most that the Ninja .28 engine is one of the 'best' truggy engines available and I think a few pages back there was a post made by Maximo? showing a dyno graph of a modded Go .25 alongside a dyno graph of a stock Ninja .28 and they were very very similar. Of course the modding helped the Go .25 but that just goes to show that it is a definite contender.
revo_race is offline
Old 01-01-2008 | 09:01 AM
  #1047
British Menace's Avatar
Hi All,
I'm looking at getting a GO-Tech Engine and pipe combo' for the new TM M1B-TURBO I'm getting and would like your advise on which to get.
Tracks will be short to Medium. A ROAR legal combination preferably. I figure with lots of bottom end power.
What do you think?
Also where to buy? I live in Davenport, Iowa U.S Anywhere close by or online?
Thanks for your help.
British Menace
British Menace is offline
Old 01-01-2008 | 09:54 AM
  #1048
TMizzle's Avatar
British,
7 port for sure in the M1... the car will handle what ever acceleration you need.
TMizzle is offline
Old 01-01-2008 | 09:56 AM
  #1049
TMizzle's Avatar
Revo Race, i should have my Pro Twister Modded .25 in a week or so. I will be running it with the new GO pipe and I will let you know how it is.
TMizzle is offline
Old 01-01-2008 | 09:57 AM
  #1050
VoodooDaddy's Avatar
I ran my Go 5 at a state indoor race this past weekend It has 2 going on 3 gallons ..I installed a o86 pipe & turbo button .. It was the first time trying this combo ... Wow what a diffrence ... The layout is super tight lap times are around 14 sec for truggy the dirt began to lay down rubber ..I had a 7mm restrictor and 20 points dailed out of the epa ... this motor would pull the wheels at will .. Yes It has some modd work done to it .. but fuel mileage was great power was awesome ... Its kinda cool to go down the straight away pull on the trigger and watch the front wheels yank off the ground ... the power band is very smooth when the wheels start to come up you know when it going to happen its that smooth and manageable .... Thanx again Brian ... Im very happy with this motor I cant thank you enough
VoodooDaddy is offline
