Like Tree2Likes
Go-Tech Engines Thread
Old 10-22-2007 | 11:15 AM
  #286
Rocket42's Avatar
The 2047 has been the pipe of choice for alot of european drivers with the 7port. It hasn't been mentioned very much because the U.S. is not required to use 3 chamber pipes. Plus with the low cost and high performance of the dynamite pipes they seem to offer a good value.
Rocket42 is offline
Old 10-22-2007 | 11:48 AM
  #287
Makes sense. Thanks for the clarification.
satoch is offline
Old 10-22-2007 | 06:21 PM
  #288
lancer mx's Avatar
Default temp
gud am guys can i please ask what maximum temp can go .28 redhead can go before overheating?and what maximum safe temp it can reach when racing?tnks guys hope somebody can help me peace
lancer mx is offline
Old 10-22-2007 | 06:47 PM
  #289
Like most motors, a safe maximum temperature is around 220-240 f.
satoch is offline
Old 10-22-2007 | 07:03 PM
  #290
lancer mx's Avatar
Default go
thanks a lot sir satoch
Old 10-22-2007 | 08:28 PM
  #291
mugenb46's Avatar
the GO motors seem to run very cool, not to cool though but a safe lower temp range for sure, the 5 ports stock seem to be very good at 220 to 225 modded a little less, the 25 and 28 should be the same. If the motor starts to get to hot, it will let you know, or the plug will. and if it is new just give it time it will drop in temps, a new motor tends to run hot intill the pinch is almost gone as Russell stated. I have a 5 and 7 port that i have done for a customer with a gallon and a half ran between the two, and i havn't turned the LSN yet, and temps are about 220 on both, still fat and a little tight, but when they get free the carb get's leaned and temps come down.
mugenb46 is offline
Old 10-23-2007 | 06:59 PM
  #292
Nitro$junkie's Avatar
Originally Posted by Rocket42
the dynamite pipes are very good, I reccomend a 053 for the 7port and a 086 for the 5port, Also Go is realeasing there own pipe very soon, it is a 2047 and is mfgr'd by hong nor, so it has the same type of stinger as a Jammin pipe.
Nitro Junkie, a novarossi turbo head button should fit as well as any 4 bolt pattern .21 head button. If you use a different mfgr. you will have to check your deck ht. and make sure its set right. You would be starting from scratch with how many shims should be required.
Nitro$junkie is offline
Old 10-24-2007 | 07:59 PM
  #293
mugenb46's Avatar
Russell, YGPM
mugenb46 is offline
Old 10-24-2007 | 11:54 PM
  #294
vti-chris's Avatar
Probably moving to Go engines!!
Go 5 port or 7 port on a buggy?
I do prefer runtime over power so i don't care which one is fastest, just which one will give me more time in the track than in the pits.
Note that i come with v-spec experience so i want to expect similar runtimes and good power.
vti-chris is offline
Old 10-25-2007 | 09:50 AM
  #295
Rocket42's Avatar
The 5port gets slightly better mileage, It will have much more bottom end power then your vspec and pull more linear.
Rocket42 is offline
Old 10-25-2007 | 10:36 AM
  #296
salteen's Avatar
Ordering two 5-ports from my LHS tomorrow. One for myself and one for my brother's Christmas present
w00t!
salteen is offline
Old 10-25-2007 | 06:55 PM
  #297
rossoh10's Avatar
w00t!
I wish I had a brother
rossoh10 is offline
Old 10-25-2007 | 07:49 PM
  #298
rabidsquirrel's Avatar
LOL!
rabidsquirrel is offline
Old 10-25-2007 | 10:44 PM
  #299
vti-chris's Avatar
What runtimes do you get with the 5 port and what should i expect with the 7 port, on race conditions of course and going FAST?
Old 10-25-2007 | 10:58 PM
  #300
Rocket42's Avatar
With the stock restrictor you should be able to pit at 7.5 min. comfortabley with both engines, run time for the 7port is around 8-8.5 min. and around 8.5-9 min. with the 5port. Some guys have gone 10 with the stock restrictor in the 5port but thats not common. To give you an example of how much a difference there is betweem drivers here is a quote from sgrid about a 7port that was run in an endurance race.
posted by Gary Kosits:
We ran a Go 7P Turbo yesterday at the 2nd Annual GMK Supply/Wolcott
Raceway 3 hour Buggy Burndown. The engine ran flawlessly with great
power for the entire 3 hours - not a single flameout or hiccup.
Perfect example of how much the driver is the variable. The most
trigger happy of the four struggled to get 7 minutes. As the oldest
and slowest of the team, they pitted me at 8:30 but said I always had
enough that I probably could go 10. The other 2 were in the 745 - 815
range. Same car, motor, fuel track on the same day, under real race
conditions. YMMV.
They ended up 3rd place.
Please remember that your engine will not get good mileage till after the engine is fully broken in at the 1-1.5 gallon mark.
Rocket42 is offline
