Go-Tech Engines Thread
#1786
British Menace, there is an indoor track that runs nitro offroad near Waterloo Ia. http://www.extremerconline.com/ They are also a Go dealer, awesome place!
I ran my 3 port for the first time this weekend and it ran awesome, it has a very smooth power band, easy to drive fast. My son ran a 7 port and it ran very well for only running it 225 deg.
Rex
Rex
#1787
It would seem from recent posts that the Go Tech engines run well at temps anywhere from 200 F up to 260+ F. I am guessing the higher temps mean better power production, but with a reduced life span. Would this be a fair assumption ?
I tune my engines pretty conservatively, as I am fairly new to the sport and don't want to cook anything
My two 5 ports (non modified with turbo heads) normally come in after a run at around 105 - 110 C (so around 220 F) when they are running good. This is using 25% fuel with standard restrictor.
Sounds like I could tune a little more aggresively with no worries perhaps
My two 5 ports (non modified with turbo heads) normally come in after a run at around 105 - 110 C (so around 220 F) when they are running good. This is using 25% fuel with standard restrictor.Sounds like I could tune a little more aggresively with no worries perhaps
#1788
maybe mine is heating up because it's still new and tight, maybe when it looses up a bit and hit the gallon the temps may go down, but still, I have to make a couple of laps to heat it up because it starts very rich, and it doesn't feel lean at 260 F, and that's not a bad temp anyway
#1792
Rex
Rex
I think I'll be going to this/these tracks too.
Thanks again!
British Menace (Tony)
#1793
Russ Jones your a very standup guy....major props to you and to the way you take care of your customers and back your engine line... I wish more of the RC industry would take a page from your book... Hopefully 2008 turns to be a very good for you and Go engines, you deserve it !!!! cheers....
FYI i was hoping to run a modded Go 7 port at the Canadian Winter Nationals, but it seems the motor I ordered never showed up..... Its either lost int he mail or held up at customs... So i will be having to run a OS 28 instead.
#1795
there are a lot of things that determine the heat you READ from an engine
Type of temp gun
Emmesivity rating of the material in the head
Head Clearence
Fuel
Pipe
Tyres
Weather
Humidity
etc etc ..
What i did with the engines at the NSW titles was to see how far we could lean them and still run reliably with my new fuel. We found 160 deg C was about as far you could go while still maintaining good performance. id say with regular fuels run them at 140 deg c .
What people regard as hot may actually be normal operating temp. When you get an engine running so hot it sags in power then you are starting to enfore pre mature wear but running an engine hot and happy will allow it to last longer ...
The happy part relies completely on the quality of the oil you use
Cheers MM
MM
Type of temp gun
Head Clearence
Fuel
Pipe
Tyres
Weather
Humidity
etc etc ..
Cheers MM
MM
#1799
Hey guys, if anyone is looking for a brand new Go 25, my dad is selling his, brand new, he bought it for his Hyper ST but sold it and bought a hyper 8 so he wants to buy a Go 21.
Here's the thread:
http://rctech.net/forum/showthread.php?t=207770
Here's the thread:
#1800
ABSOLUTELY ! thats the whole reason i started using it , i tune a lot of engines in doors and every bit helps . I too love the smell of raw Nitro but after a while it gets to you.
Id say it reduces the irritation and burn by about 50% .. It also keeps the neighbours happy when they smell cinnamon coming out of my shop as opposed to buring oil and Nitro .. lol
2Likes
