Like Tree2Likes
Go-Tech Engines Thread
Old 10-21-2007 | 03:23 PM
  #271
Rocket42's Avatar
richen the HSN and the LSN 1 hour, you want the temps to be in the 220-230 range, If there is still metal pinch in the engine it will want to run 260-270, but just richen it and try and get the temps down and be patient for the pinch to go away.
Rocket42 is offline
Old 10-21-2007 | 05:14 PM
  #272
rossoh10's Avatar
I got a chance to go to the track today,finally.I didn`t add another shim because I didn`t get any extra and my lhs shop didn`t have any .21 shims in stock.I started to retune froim factory setting`s.I got the engine running right around 200 and left the HSN alone,then I gave it a 2 hour turn on the bottom so it would be so boggy.I`m gonna leave where it is at untill I get more fuel through it.PLus the track I went to was real small and the track I race on is hugh.I figured 200 temp is good because when I get on the bigger track my emps are gonna rise a we bit because it a full throttle kinda track..
Thanks for everyones help
rossoh10 is offline
Old 10-21-2007 | 05:46 PM
  #273
Sorry guys, another 3 port question. I have a choice of the following pipes 053, 086, TT 2035, or TT 2039. Which one would be best suited for the 3 port overall? Thanks for you help in advance!
g26er is offline
Old 10-21-2007 | 06:55 PM
  #274
Rocket42's Avatar
Never tested the TT pipes but the 086 would be better than the 053
Rocket42 is offline
Old 10-22-2007 | 02:49 AM
  #275
Nitro$junkie's Avatar
would a Novarossi turbo head button fit
Nitro$junkie is offline
Old 10-22-2007 | 04:40 AM
  #276
friend2friend's Avatar
Default whats the best go tech
whats the best go tech to get?
the 5 or 7 port?
turbo or standard plug?
friend2friend is offline
Old 10-22-2007 | 04:44 AM
  #277
GenReaper's Avatar
5 port Turbo.
GenReaper is offline
Old 10-22-2007 | 05:46 AM
  #278
Default what sort of pipe?
what sort of pipe would you run with the 5 port turbo and the 7 port turbo?
also what are the best cluches to use?
im new to this and appreciate all the advice!
Old 10-22-2007 | 05:57 AM
  #279
salteen's Avatar
Has anybody used the clutch/flywheel set up that comes with the RC8 on thier Go Tech? I'm just wondering if there are any issues with doing that because I am going to be ordering a 5 port this weekend for my RC8 and I plan to use the flywheel and clutch shoes that come with it. If I remember correctly the clutch is a 3 shoe set up.
salteen is offline
Old 10-22-2007 | 06:31 AM
  #280
GenReaper's Avatar
Ofna Alloy shoes, blue, 1.1mm springs
Hobao flywheel.
OS 2050 pipe
5 port.
JP2 pipe would be good on a 7 port.
Old 10-22-2007 | 07:54 AM
  #281
Brandon Melton's Avatar
I ran the 5 port turbo with the RC8 clutch setup straight out of the box with the 16 tooth clutch bell. Ran good.
I finished 2nd and a Go Tech team driver finished 3rd. This was at a competitive race with about 40 cars in pro buggy. I ran the dynamite 053 and he ran 086. At about the same running temps he got about 2 more mins to a tank on a 8eight, so I am going to try 086 to see if my mileage improves.
He could go 10 mins to a tank which is awesome.
Brandon Melton is offline
Old 10-22-2007 | 09:20 AM
  #282
salteen's Avatar
^very good info. thank you!
I'm going to be looking for a pipe too and I have been partial to the Dynamites based on price alone lol so you helped out in that department as well.
I can't wait to get a good powerplant in this buggy and push it to its full potential.
salteen is offline
Old 10-22-2007 | 09:54 AM
  #283
Rocket42's Avatar
the dynamite pipes are very good, I reccomend a 053 for the 7port and a 086 for the 5port, Also Go is realeasing there own pipe very soon, it is a 2047 and is mfgr'd by hong nor, so it has the same type of stinger as a Jammin pipe.
Nitro Junkie, a novarossi turbo head button should fit as well as any 4 bolt pattern .21 head button. If you use a different mfgr. you will have to check your deck ht. and make sure its set right. You would be starting from scratch with how many shims should be required.
Rocket42 is offline
Old 10-22-2007 | 10:06 AM
  #284
salteen's Avatar
I love it when great products are very affordable (Go Tech's engines and Dynamite's pipes.) My wife loves it more.
salteen is offline
Old 10-22-2007 | 10:47 AM
  #285
There's never been any talk of using a 2047 pipe on the 5 or 7 port as best I recall. Why was this one chosen?
satoch is offline
