Go-Tech Engines Thread
#9061
Not a problem matt, give me a call tomorrow afternoon and I'll get everything lined up for you. Thx
Also a big Congrats to Kendall!!!!!
http://www.neobuggy.net/modules/news...p?storyid=7116
#9062
hey guys
im new to rc's probly roughly 6 months . had china cookie buggy that crumbled and got a decent one i just brought a go tech 5port for it.
have a few questions about the engine.
i used the heatgun on it and put foil round the head and it fired first pop but wouldnt keep running( very rich i think) i had to leave the glow ignitor on for it to keep running? is this normal?
also i was only using not even quarter throttle and thing looked like it would pull a tree stump out the ground. is it to lean? its got heaps of smoke splattering all over the joint tho so im confused!
everything is brand spanking new ive only ran 1 tank so far like that but wanted to get some advise b4 i keep going with it.
cheers brett
cheers brett
#9063
#9066
Thats sickJust search massivemods+dyno on youtube
#9067
ok heres the video , we have worked out why the reading was so high . the wheel ratios were double so the reading doubled ,, so the 6.4 hp reading was really 3.2 hp on that dyno .. we did 22 passes and they were consistant .. mind you we were running on 7% nitro
http://www.youtube.com/watch?v=nPxpTNsVjKA
MM
MM
#9068
Troy
#9070
In my opinion, that video is pure BULL SHOT.
Until the MG66 gets tested on a, industry standard,
X-Dyno here in the U.S. and I see the real numbers
I will wait to buy one. Let the guys that live where
the weather is warm enough to race this time of year
buy them and give there reviews on it. Just wait until
the engine modding gurus here in the U.S. get a chance
to test and tweek the MG66. There opinions are whats
going to be the real test of the MG66.
#9072
MM
MM
I got a lot of explaining to do
I told a lot of people about that dyno result u guys did
#9073
#9074
#9075
hey guys
cheers brett
cheers brett
Lean out your low end until it will idle properly. You "may" have to richen up the high end just a tick if it is already clearing out when you give it throttle. Sounds like you are doing everything just fine. Make sure your temps stay above 200F so you dont develop slop in your rod. Good luck and have fun the 5 port is a power house.
2Likes
