Go-Tech Engines Thread
#1561
#1565
#1567
I fitted the turbo head button after 1.5 gal as well, and it made a big difference in overall performance.
Indigo - love that Storm CL-1 - from one Storm driver to another
#1568
does anyone know if the ball link from an OS carb will fit on the 5 port carb?
I have a GO and OS engine I have, and it's a PITA to have to swap ball cups on the linkage from small and large each time. I'd like to buy an extra OS ball link end pc. and put it on the 5 port.
#1569
Its a pain in the butt but its worth the wait, you will know when its there cause run time increases alot.
#1571
#1572
when I first ran the 5 port, I had to put a ball cup from the GT2 linkage on my RC8, because it kept popping off the Go carb. when comparing the vspec and Go ball links side by side they (GO) are smaller.
#1574
I ordered the one for the Novarossi carbs the number is NT116-R-B. If you can't find your engine listed then use a set of calipers (if you have them) and measure your HSN housing as directed on the site.
This was taken from R/C Hardware website:
Engines not in the list can usually be fitted with a N-Tune tuning dial.
Measurements must be taken with precision calipers or micrometers.
Diameter measurements are the most important and height measurements
are some what less critical for the designed fit.
Height is the distance from
the top of the housing to
the top of, or beginning of
the nut.
#1575
your lucky the ball cup has never popped off the 5 port, unless your using the smaller ball cup on the Vspec.
Hope this helps
www.massivemods.com
2Likes
