Like Tree2Likes
Go-Tech Engines Thread
Old 02-07-2008 | 04:11 PM
  #1576
GoTech 7 port -
Guys, I ran the Go 7 port modded by ProTwister Mods this weekend and
it was awesome. Great linear power band and held a tune all weekend in
the rough, dusty conditions. It really made it through a tough race on
this one. No problems at all running the Go Tech against anything on the track.
Brandon Powell is offline
Old 02-07-2008 | 04:34 PM
  #1577
Ive been thinking of getting a go race 3 port. Are they out yet and if they are what website is selling them. If not out yet what site will be selling them. GO is looking great from couple people ie seen running them and the 3 port looks like even better for the small track i run.
hiredgunbl2 is offline
Old 02-07-2008 | 04:44 PM
  #1578
Brandon Melton's Avatar
Originally Posted by MassiveMods
The Ball off the 20 e range wont go on .. the 21 range of OS carbs the ball will fit for the Go carb no problem , that cobvers V Spev up to OS Speed models.
Hope this helps
www.massivemods.com
good info, thanks
Brandon Melton is offline
Old 02-07-2008 | 07:24 PM
  #1579
TheBackmarker's Avatar
hiredgunbl2, The 3 port race is in stock with the distributor. I have some coming within a couple days. I'm in Florida and UPS ground will get it to you in one day. Call if you want one.
Dave Webb
B&B Hobbies
Hudson, FL
727-862-4849
TheBackmarker is offline
Old 02-07-2008 | 08:40 PM
  #1580
Rocket42's Avatar
Hey guys I just wanted to give a quick run down from Atlanta. All I can say is wow about the track big huge air, was equally impressive to see guys 20ft. in the air doing backflips over a 50ft. gap. I personally like rough tracks so I was liking how blown out the track got.
About the team guys it was great to meet all you guys, everyone a class act, helpful, fast on the track, and great ambassadors to our sport. I feel great about the team going into 08, I hope we can continue to grow as a company and provide the racers with better products all the time. I saw more Go engines at this race then I have ever seen at a single race before, I feel we are off to a great start this year.
I just want a say a big thanks to all the drivers using Go power, I will continue to push hard this year and try and supply quality products and stay true to the company motto, for racers by racers.
Rocket42 is offline
Old 02-07-2008 | 09:21 PM
  #1581
mugenb46's Avatar
Gary Fitzgerald, call me asap, i need your address.
mugenb46 is offline
Old 02-07-2008 | 10:03 PM
  #1582
Brian did you get my PM ?
JustinD is offline
Old 02-07-2008 | 10:20 PM
  #1583
zJatoRad's Avatar
how would the Go Tech 5 Port w/ standard plugs run with RB standard #6 medium plug? only reason I want to use them is because that's what my LHS stocks.
zJatoRad is offline
Old 02-08-2008 | 09:07 AM
  #1584
Rocket42's Avatar
It will probably run alright with those plugs but effiency will be down. The Go engines use the short threaded plugs and the Novarossi's are long threads, You will either need to use the Go plugs or the O.S. compatible plugs. For O.S. I would try the #8 or A3, o'donnel also makes a o.s. compatible plug and I would say try the 97 and 99 standard plugs. You can always get your local shop to set up an account with Racefactor Industries and then they will be able to carry the Go plugs.
Rocket42 is offline
Old 02-08-2008 | 09:11 AM
  #1585
zJatoRad's Avatar
oh I thought I could not use OS Plugs, I guess I read wrong, I will use OS #8 plugs then, thanks for the info!
zJatoRad is offline
Old 02-08-2008 | 02:04 PM
  #1586
22Racer's Avatar
Can you just add a washer to the Novarossi plug?
Rex
22Racer is offline
Old 02-08-2008 | 03:48 PM
  #1587
MassiveMods's Avatar
The long body standard plugs will work , however they protrude into the geo dome. This has 1 positive effect and 2 negatives
Positive is that it can increase torque
Negatives are it reduces idle and top end
the effects are small but some will notice them
best bet is to get short body in standard plugs
Cheers MM
www.massivemods.com
MassiveMods is offline
Old 02-08-2008 | 10:27 PM
  #1588
zJatoRad's Avatar
how come A-Main only stock parts for the Go 28 and not the GO 25, are the parts between them similar or the same? or what's up? I ask because my uncle wants to get a Go engine for his Hyper ST PRO, I can get a 25 a lot cheaper than the 28 but my concern is that I can't find parts for the 25 but only for the 28.
zJatoRad is offline
  #1589
zJatoRad's Avatar
RCTech Server Double Post.
zJatoRad is offline
Old 02-08-2008 | 11:53 PM
  #1590
I thought someone said the internals were identical, I'm assuming the piston/sleeve or conrod or crank has to be different though since the displacement is different between the two. The .28 is absolutely insane, I'd definitely try the .25 as well if I had a choice. It probably gets slightly better fuel mileage and still will have plenty of power to get around most tracks in a timely manner. Even if amain doesn't stock .25 parts...they can get anything from Russel and he probably has it in stock so it won't be more than a few days for amain to get the correct parts in stock. I wouldn't base your decision solely on that if I were you...if you're more interested in the .25 get it and don't look back. In the event of needing new internal parts simply call one of the retailers and for them getting the correct parts shouldn't be an issue. Russel ships stuff out usually the same day payment is sent so it won't take long for you to get it.
revo_race is offline
