Like Tree2Likes
Go-Tech Engines Thread
Old 12-14-2007 | 05:37 PM
  #841
If it spins too easily then the bore needs to be cleaned, replace the O-ring, and put some type of lubricant on it like Green Slime. I just replaced my O-rings for the same reason.
satoch is offline
Old 12-14-2007 | 09:34 PM
  #842
Rocket42's Avatar
Salteen thanks for getting your shop to carry the engines. First the O-ring is in the right spot. If the needle turns easy the o-ring could be bad but the o-ring looks fine in the picture. If you pressure test the carb and there arn't any air bubbles coming out of the HSN then you should be fine, but since you have it out i would also reccomend using a grease like Satoch said.
Rltanner, you will have to send the coupon to me it will not be accepted by any dealers.
Rocket42 is offline
Old 12-15-2007 | 12:37 AM
  #843
mugenb46's Avatar
I took the TQ and A main win tonight, running the 7 port, Russell, the 2047 ROCKS, can't wait to run it on the 3 port. Jason, i know man just messin with ya, i have been looking at alot of things on dyno's i'm not sure how they compare to chassis dyno's but i know doing numerous pulls on a motor is hard on them, thats why i said a new motor, i would like to have a pull done on the 3 5 and 7 ports, just not sure where to get a good reading from, EB offers a pull for $100 with a few differnt pipes, and he doesnt open them up when there from someone else. Russell, give me a shout when you can bud.
mugenb46 is offline
Old 12-15-2007 | 09:29 AM
  #844
Rocket42's Avatar
Big congrats mugen, was that on that tight indoor track you race on.
Rocket42 is offline
Old 12-15-2007 | 04:13 PM
  #845
mugenb46's Avatar
Ya the track had a new layout for our TN state indoor championships on the 29th of this month, i was still able to post a 13.5 fast time, so even with the new lay out it was very fast, motor and pipe were flawless.
PTM 08 GO 7 port
GO 2047 pipe long header
OS P6
Rocket Science 30%
NR 7 MM carb insert
mugenb46 is offline
Old 12-15-2007 | 04:21 PM
  #846
mugenb46's Avatar
russell, any word on what motor Ashton is running at the CRCRC in Jan
mugenb46 is offline
Old 12-16-2007 | 11:59 AM
  #847
D Hunt 3's Avatar
What would be the best pipe for the 5 port for high bite indoor racing on a Losi 8ight?
Thanks.
D Hunt 3 is offline
Old 12-16-2007 | 01:33 PM
  #848
Jason Halvorson's Avatar
Thanks.
use the 086 or the 2047....
Jason Halvorson is offline
Old 12-16-2007 | 02:11 PM
  #849
Rocket42's Avatar
On high bite indoor you may want to try the 053, the engine will have tons of bottom so if you can get traction you should be able to pull out of the corners very fast.
Rocket42 is offline
Old 12-16-2007 | 02:42 PM
  #850
had a friend of mine racing with his GOTech 5port against some of the best engines on the market as well as expensive, and it sure is money well spent considering the price and quality and performance overall.
DirtRacer is offline
Old 12-16-2007 | 02:52 PM
  #851
i got a dynamite 007 pipe, so im gonna try this pipe with the 7port on short track high bite conditions...
  #852
D Hunt 3's Avatar
Ok thanks. If I get the turbo head what would be some good glow plugs to pick up?
D Hunt 3 is offline
Old 12-16-2007 | 04:24 PM
  #853
i have been using the Nova #7 short asd OD97T with lots of success on all my Go turbo engines...
Old 12-16-2007 | 04:46 PM
  #854
mugenb46's Avatar
Jason, i ran the 2047 friday night on our track, the pipe is killer on the 7 port, may give it a try, the A main was stacked with some brutal motors 3 or 4 speeds and a few 367s, the pipe is good man russell any word on Ashton?
mugenb46 is offline
Old 12-16-2007 | 04:56 PM
  #855
i have ran the 2047 on my 7port, but i had a low end bog...im wondering if i just need a few more tanks on it...
i just bought a RB 2045 with long and short headers today so im gonna give them a few test tanks with each of the engines...i also picked up a Nova 9886 to check out...i got them so cheap that if they doent work well for me i can get my money back out of them...i would like to get another werks 2013...i used a friends, and wow that thing ripped on the 7port...
