Like Tree2Likes
Go-Tech Engines Thread
Old 12-10-2007 | 07:09 PM
  #781
MassiveMods's Avatar
Originally Posted by grizz1
Massive, I see you have the new GO 3 Chamber 2047 pipes on your site.
Have you done any tests yet to compare this new pipe with the LRP 2063. I am keen to know which pipe out of these two will work best on the 5 Port in a truggy ?
Wow thats a hard one .. The New Go Pipe is awesome , smooth and economical , the LRP has just a little more snap but is a tad thirstier than the Go 2047.
Both are awesome , im torn which one to recommend ..
MassiveMods is offline
Old 12-10-2007 | 07:19 PM
  #782
mugenb46's Avatar
mugenb46 is offline
Old 12-10-2007 | 07:53 PM
  #783
Jason Halvorson's Avatar
i havent ran the 2063, but i have ran the 2047 on the 5port with great results...
Jason Halvorson is offline
Old 12-10-2007 | 08:35 PM
  #784
they are both really well performing pipes.. it would be down to personal prefrence..
Old 12-10-2007 | 10:13 PM
  #785
RETRO RC's Avatar
hey Mark I haven't seen a go 2047 pipe in person yet but looking at the pics it looks like a rebadged Hong Nor pipe is this the case or not
also what would your turn around be on a 7port turbo from NZ it's due for a check up after the nats this weekend either stage 5 or 6 mod
thanks Adrian
RETRO RC is offline
Old 12-11-2007 | 02:04 AM
  #786
grizz1's Avatar
Hmm - you have left me wondering guys.
Jason, I have a 5 Port (soon to be turbo head) in my buggy with a Dynamite 086 fitted. Allowing for the cost factor, do you think it would be worth while changing this to the new GO 2047, or is the performance so close it wouldn't matter ?
Thanks Mark, I will have to think about which pipe to get. Truggy on pretty tight lay outs with Turbo 5 Port - I am leaning LRP way. I have seen two different pics of the LRP 2063 pipe so perhaps you could confirm for me - does it have a re-inforced stinger ?
Sorry to be buggin you guys with so many questions, but I want to get the best set up possible first time around for both my rides. Plus I don't think the other half will put up with too much more expenditure on my "toys"
Thanks - grizz
PS: Retro - good luck at the nationals mate. I hope to get down to Hamilton for a look at the finals on Sunday if everything goes to plan.
grizz1 is offline
Old 12-11-2007 | 05:59 AM
  #787
grizz you have pm...
Old 12-11-2007 | 06:55 AM
  #788
Originally Posted by mugenb46
Lon-L what pipe did you use on the 5 port?
Iran the HN2047 for the first quals, and then the OS 2060 for the last 2 quals and the main. Noth pipes yeilded 10 mins of run time and felt almost identical.
Lon_L is offline
Old 12-11-2007 | 09:15 AM
  #789
salteen's Avatar
Originally Posted by Rocket42
Salteen. That sounds like a air leak, take off the carb and pressure test it, you may have a tear in your carb boot. You also will want to check the fuel tank and fuel filter. If all that checks out it would be a lean LSN, so you may want to check your idle gap and then Richen your LSN.
an air leak at less than one gallon would suck...I'll check it out as soon as I get my buggy back together. I thought that it may have been an exhaust leak too but all the gaskets checked out fine when I broke it down. It's really giving me a fit though whatever it is.
salteen is offline
Old 12-11-2007 | 10:31 AM
  #790
mugenb46's Avatar
Salteen, YGPM
mugenb46 is offline
Old 12-11-2007 | 01:18 PM
  #791
grizz1's Avatar
Jason, you have PM
grizz1 is offline
Old 12-11-2007 | 04:02 PM
  #792
rltanner's Avatar
Im going to get the GO Tech 21 but don't know if i should go with the 5,7 port what do you suggest its going in my VTX buggy and i've got a JP-2 pipe is that good enough for that motor?
rltanner is offline
Old 12-11-2007 | 04:24 PM
  #793
mugenb46's Avatar
what kind of power delivery do you like, if you like real strong bottom with great top the 5 ports are awesome, like smooth bottom and very strong mid to top the 7 port, the JP2 is fine if thats all you have they will work good with that, the 5 more so than the 7. i love the 5 ports, but my 7 port is taken care of business
mugenb46 is offline
Old 12-11-2007 | 04:29 PM
  #794
rltanner's Avatar
Thankz dude my home track is'nt that big its more of a 10th scale track but i do go to the Nitro Pit and that track is big i like the smooth top i guess i'll go with the 5 port thankz again for the info
rltanner is offline
Old 12-11-2007 | 05:22 PM
  #795
if its a hi traction surface go with the 5port, if its a loose surface go with the 7port to help keep control wheel spin...
as for pipes...i would get something other than the JP-2...i would look into a 086 for a 5port and a 053 for 7port...the dynamite pipes are very nice for only $50 each...
