Like Tree2Likes
Go-Tech Engines Thread
Old 06-14-2009 | 02:42 PM
  #7201
grizz1's Avatar
Originally Posted by 2fst2c
Ok, trying to find out what's going on with my motor. Got a 5pt that I rebuilt with ceramic rear bearing, new piston,rod,sleeve and front bearing. Heated it up and broke it in like every other motor. Ran about 1/2 gal breaking it in and then started tuning it for more power. Well got about 8 more tanks on it and the wrist pin clip broke messing up the P/S/R. So bought another P/S/R and tore the motor down and cleaned it all out again and installed the new P/S/R. Broke this one in and got just over a gallon on this one and like clock work the thing died. Took it apart and guess what. Wrist pin clip broke again and ruined another P/S/R. Getting tired of throwing 100.00 P/S/R in this thing every Gallon. I really liked my GO motor but I think I'm about to junk it and go to Nova. Anyone else have issues like this?
All I can think of is the C clips are not properly seated, or they are getting damaged some how when you are installing them. Is the little tab piece breaking off and leaving the rest of the clip seated in the piston, or is the whole clip coming out ? I use a jewellers magnifiing eyepiece to check the clips are properly seated when I change them (yeah I know I'm getting old and going blind ). But it can be hard to see if they are locked into the groove properly. Just a tip I was given - install the clips with the gap facing vertically, not horizontal. At high revs the clips can contract and on the odd occasion contract enough to pop out of the groove. If they gap is vertical when installed it helps to keep them in (apparently so, according to a 2 stroke motorbike racing friend). Something to consider.
It's not a common problem as far as I know.
Originally Posted by moeman
As much as I wanted to believe in these mills, I'm not convinced anymore. The carbs are absolute junk, as I've replaced the o-rings many times only to have them fall apart again and again. Put a V-spec carb on it, it will tune normal and run normal, and you won't have to replace o-rings every few tanks. This is only MY opinion and not meant to piss anyone off, cuz that's not why I'm here. I was just as fustrated with these motors and probably blew $300 in glow plugs to get it to stay running.
Easy solution - Replace the shonky O rings with fuel tubing (see my post some pages back, or PM me for details). Or get a set of Nitrile O rings from Massive Mods in Australia.
Take out the long LSN (which is what will be causing your tuning problems - hence blown plugs - too lean on top) and shorten it from 1.6" down to 1.42" with a rounded end. Fit it back in and your GO will tune like any other motor out there.
I run the fuel tubing O rings and shorter needle in both my GO's and have no problems what so ever. Awesome performance, 12 min + run times, super reliability.
grizz1 is offline
Old 06-14-2009 | 02:43 PM
  #7202
2fst2c's Avatar
Originally Posted by RETRO RC
I myself have never broken a wrist pin and with out being able to see the engine and go over it first hand it's a bit of a lottery on the anwsers you'll get.
I would suggest maybe sending it to someone to have a good look over it for you as there maybe a small under lying problem that you may have overlooked and some times a fresh set off eyes see thing we miss ourselves. try 22Racer from all accounts it sounds like he does a very good job at resonable prices
Adrian
It didn't break the pin. The clip that holds the pin in broke and locked up the piston. Twice now with new P/S/R's.
2fst2c is offline
Old 06-14-2009 | 04:02 PM
  #7203
grizz1's Avatar
Hi Adrian, Pity about the weather last weekend. I was looking forward to seeing your new Gen 5.5 7 Port go hard
Never mind, next meeting we should have the 2072's bolted on
I am keen to see how these pipes will perform. Everyone so far has been very pleased with the performance. My only concern is that the larger volume chamber will not fit into the X Ray without melting the tank or the body. It's a pretty tight fit in there with the slightly angled engine mounting on the Ray.
See you at the Tron in July
grizz1 is offline
Old 06-14-2009 | 04:24 PM
  #7204
bigmatt's Avatar
I noticed when I did mine it did not want to fit in or seat all the way. that's what it looked like. I took a small screw driver and spun mine around in the hole to make sure it was set all the way in. and it did pop in further. just a suggestion.
bigmatt is offline
Old 06-14-2009 | 05:16 PM
  #7205
mattwoodcraft's Avatar
thats a good idea Matt the clips are so dam small and the groove to we all need a huge pair magnifing glass to see it properly ,as grizz said
mattwoodcraft is offline
Old 06-14-2009 | 05:40 PM
  #7206
2fst2c's Avatar
I did look at it like I do all of them I put in but it looked like it was in to me. I'll make sure I check the next one if I decide to drop another 100.00 at this thing.
2fst2c is offline
Old 06-14-2009 | 06:23 PM
  #7207
RETRO RC's Avatar
sorry man, I miss read your post, like grizz and big matt have posted I always check the clip even on a new P/S/R set as nobodies perfect even a factory.
RETRO RC is offline
Old 06-14-2009 | 06:27 PM
  #7208
RETRO RC's Avatar
yeh the weather over here sux at the moment. I dont think there should be too much of an issue with the 2072 fitting in the 808 as I'm thinking it will be similar in size to the 2047 but maybe 1 of the aussie boys who have 1 could shed some light on the subject.
RETRO RC is offline
Old 06-14-2009 | 06:39 PM
  #7209
2fst2c's Avatar
But what are the chances of getting 2 in a row that did the same exact thing from 2 different suppliers?
2fst2c is offline
Old 06-14-2009 | 06:51 PM
  #7210
bigmatt's Avatar
The way I install the clips and wrist pin are as follows. I install one c clip in the piston first,then install rod and con-rod. then I push on the wrist pin with a phillips screw driver to make sure the pin would not go through the other side. That tells me the c-clip is seated into the groove. do the same for other c-clip take magnifier to make sure all of the c-clip is seated in the slot.
bigmatt is offline
Old 06-14-2009 | 06:59 PM
  #7211
RETRO RC's Avatar
All i could put it down to is really really bad luck but like i said earlier there maybe some underlying problem thats you've missed we all do it when your looking at something and your frustrated because you can't figure it out ...you miss a little thing that can make all the difference.
hell I missed the word "clip" in your first post
maybe send it off to someone like 22 racer to look at it you just never know
Adrian
RETRO RC is offline
Old 06-14-2009 | 07:00 PM
  #7212
2fst2c's Avatar
Well I'll be sure to double check next time. I've never had a clip break in any of my other motors before and it's just kinda crazy I get 2 that blow with less than 2 gallons combined. I would think if the clip wasn't in all the way, it would of came out during break in with all the extra fuel going in and all. I pulled the pin just to look at it and both ends are severely worn. That's something I've never seen yet either. You'd think this thing had 10 gallons on it.
2fst2c is offline
Old 06-14-2009 | 07:02 PM
  #7213
2fst2c's Avatar
Adrian
Ya I know what you mean. I am going to get in touch with Mark at Massive or 22racer and see what they think. I just started break in on my 7 port. If it does the same thing I'm going to shit kittens.
2fst2c is offline
Old 06-14-2009 | 07:08 PM
  #7214
RETRO RC's Avatar
I know how you feel I used to run Nova's until they changed to 14.5mm rear bearings and i had 2 plus-5t's drop rear bearings at under2 gallons and the cost of a rear bearing alone was almost as much as a P/S/R set for a go when the 2nd engine went it took the P/S/r with it now it's a very expensive bookend
good luck I hope you get it sorted
RETRO RC is offline
Old 06-14-2009 | 07:15 PM
  #7215
2fst2c's Avatar
Thanks, so do I. Do all the Nova's have that issue? I Got a P5XS too and wonder if I should look at it before counting on it as a back up.
2fst2c is offline
