Like Tree2Likes
Go-Tech Engines Thread
Old 11-13-2008 | 05:42 AM
  #4666
Originally Posted by will g
i would recommend if you are keeping that for good back up to send it to Rex Welch (22racer)to have it pinched and i would check bearings to make sure all good and replace with con rod and get another boot on there. if cant get one msg russell(rocket42) he may be able to get you one. Rex does an awesome job and im going to keep sending motors to him . The new gen motors are just as good as the older ones to me, but im sure others see differences. just my opinion thnx Will G
Agreed, Rex does a great job!!
REVX is offline
Old 11-13-2008 | 07:53 AM
  #4667
hobdog's Avatar
Well, I sent it off to Rex, we will see what kind of majic he can produce.
hobdog is offline
Old 11-13-2008 | 08:19 AM
  #4668
will g's Avatar
do you still need carb boot i think i found extra one here for it thnx will g
will g is offline
Old 11-13-2008 | 01:56 PM
  #4669
dc*90's Avatar
what are the advantages of the 3r over the 3s?
dc*90 is offline
Old 11-13-2008 | 02:00 PM
  #4670
Rocket42's Avatar
The 3r uses a larger higher quality rear bearing, has a bigger cooling head and comes with a turbo button, Also the timing is not the same.
The 3s is a amazing engine for the money its powerband is very short and it spools up very fast, it can be a benefit on very tight tracks.
All in all the 3r will have a long smooth powerband and the 3s will have a short powerband that spools up fast, both engines get good mileage.
Rocket42 is offline
Old 11-13-2008 | 02:06 PM
  #4671
dc*90's Avatar
thanks looks like ill be getting the 3r then. our track is a decent size but is quite technical so
dc*90 is offline
Old 11-13-2008 | 02:12 PM
  #4672
j_blaze14's Avatar
the 3r is ballistic, i must have a good one cause mine has had no issues in 2 gallons and screams, very very happy with mine so far. here's my next motor tho...
http://www.neobuggy.net/modules/news...p?storyid=5073
j_blaze14 is offline
Old 11-13-2008 | 02:50 PM
  #4673
Is that GO 5PT engine made for Caster to Casters specifications?
Jesussaves is offline
Old 11-13-2008 | 04:00 PM
  #4674
22Racer's Avatar
It sure looks like a Go!
Rex
22Racer is offline
Old 11-13-2008 | 04:42 PM
  #4675
RETRO RC's Avatar
It's a Go 5pt alright just like OCM had. I really like the look of the cooling head very nice. it'll be interesting to see how it's priced compared to the Go engine.
RETRO RC is offline
Old 11-13-2008 | 06:21 PM
  #4676
22Racer, u got PM,,,, thanks
justag3 is offline
Old 11-14-2008 | 10:13 AM
  #4677
tagalong_74's Avatar
I have the .21 seven port turbo and it had been the best motor I have ever owned. Sent it in to russell here to make sure everything was alright with it over the winter. Will have a brand new one come next spring.
tagalong_74 is offline
Old 11-14-2008 | 10:51 AM
  #4678
chunk t's Avatar
Default engine mods, what's common
This question is directed to anyone who wants to throw an answer back my way. I'm not new to mod'ing engines or R/C. Just new to R/C with wheels. Anyway... what are common mods to R/C car/truck engines?
Changing bubble volume
changing bubble shape
changing deck height
tapering squish bands
changing Compresion Ratios
changing port timing
"turbo'ing" cranks
and so on...............
Having a boat background Im used to moding the crap out of engines to have peak torque and HP at un-godly RPMs.
Right now my intrest in trucks is ripping down the street, not racing
chunk
chunk t is offline
Old 11-14-2008 | 06:10 PM
  #4679
so i just got a brand new trinity .12 touring edition draked. 1.62bhp and 44000rpm. its not bad...... but i need help finding a clutch nut for it. Does anyone know what i nut would fit? thankks
rcdude236 is offline
Old 11-14-2008 | 08:16 PM
  #4680
the carb on my 3r has devoleped the "wiggle" i remember reading here about. couldnt find a post about a fix. it seems to be leaking fuel around the base of the carb and running lean. any suggestions??
nitro0619 is offline
