Like Tree2Likes
Go-Tech Engines Thread
Old 10-15-2008 | 04:29 AM
  #4516
Originally Posted by MMor101
Anybody have an 0801 they wanna get rid of?
I've got one listed on the for sale forum along with a new .25 and everything else I have.
ab18th is offline
Old 10-15-2008 | 12:54 PM
  #4517
ConciliumDesign's Avatar
Originally Posted by grizz1
Hey Adrian, how goes it buddy. Talking of broken motors - my 7 Port has expired
The wrist pin clip either broke or popped out and got caught in the exhaust port before travelling the full length of the bore whilst attached to the side of the piston - arrghhhhhh Was checking buggy over the other day and noticed a distinct lack of compression in the motor (no wonder !!). Strip down revealled a big gouge in the piston and sleeve. So it's a rebuild coming up. I think it was my fault, as I recently replaced the rod and maybe didn't seat the clip properly. Darn this failing eyesight as you get older An expensive but well learned lesson. It's a real bummer as the motor had just done 2 gallons and was really starting to scream at the last ARCCC meeting.
Lucky I have my MMods Stage 5 5 Port to break in, which eases the pain considerably It sounds nasty even after only 3 tanks
I had the same thing happen to me with my 7 port @ 1.75 gallons before I had a chance to change the rod. The engine seized with the clip stuck between the piston and sleeve.
Has anyone tried the Associated Factory team 2035 pipe on a 7 port yet? If so, how does it compare to the 0801 and the 053?
ConciliumDesign is offline
Old 10-15-2008 | 05:27 PM
  #4518
RETRO RC's Avatar
I've tried the ttr 2035 which is the same pipe rebadged for associated
they work OK the bottom feels a little weak compared to the 0801 top end is about the same but the run time is better with the 0801
my favourite combo for the 7PT is still the Go or Hong nor 2047 with a long header pipe, either the RB 98mm or the header from the 0801 pipe set
the combo really brings the bottom end to life without losing top end or run time
Just my choice
Adrian
RETRO RC is offline
Old 10-15-2008 | 05:51 PM
  #4519
22Racer's Avatar
Congrats to Kendall Welch for winning the Minnesota Nitro series 1/8 scale buggy pro championship. He used Go 7 and 5 port motors in his Kyosho buggy. It's a tough series, most of the top ten in the series have chassis sponsors.
Rex
22Racer is offline
Old 10-15-2008 | 06:55 PM
  #4520
Rocket42's Avatar
Big Congrats to Kendall that is a awesome finish against some tuff competition.
22 racer ygpm
Rocket42 is offline
Old 10-15-2008 | 08:11 PM
  #4521
zJatoRad's Avatar
does any Go dealer have the Go Venturi Set in stock?
zJatoRad is offline
Old 10-15-2008 | 08:15 PM
  #4522
Rocket42's Avatar
Check the dealer page at Racefactorindustries.com anyone of them should have or be able to get in stock the restrictor set.
Rocket42 is offline
Old 10-16-2008 | 03:31 PM
  #4523
clio's Avatar
Hi, for the next week i will be on vacation in florida and i would like to pick up a Go tech 5 port engine somewhere. Can anyone give me one/some rc shops in florida where i can go for that? We will do a tour by car between Miami and Orlando.
Greetings Hans
clio is offline
Old 10-16-2008 | 04:10 PM
  #4524
yeaklet4's Avatar
so how r the standard 3 port motors peformance,fuel mileage and relieabilty i know u cant have much at 125 bucks. but i thought i would ask.
yeaklet4 is offline
Old 10-16-2008 | 04:19 PM
  #4525
j_blaze14's Avatar
i think the standard 3 port is an rtr motor, for $60 more you can have the race 3 port which is ballistic. don't skimp on motor cause you are just gonna get a nother one anyways, get a good one to start.
what does the nova rossi carb do to te go motors? i've heard "they really wake up" and "they are easier to tune" but all i got was less run time and a slightly larger tuning window, i'm going back.
j_blaze14 is offline
Old 10-16-2008 | 04:23 PM
  #4526
Akhor's Avatar
hmm. It's not bad. I ran it all season. Although I did struggle with a tune for a time.
My understanding is the diff between the standard and teh race is the plug type.
Akhor is offline
Old 10-16-2008 | 04:48 PM
  #4527
RETRO RC's Avatar
there is a big difference between the 3 pt sport and the 3pt r spec not just the head type
they have different carbs, crank, crankcase, sleave etc.
The 3pt sport is an ok budget motor and with the addition of a turbo head button are pretty reliable but I would spend the extra and get the R-spec as it's a lot more of an engine.
Adrian
RETRO RC is offline
Old 10-16-2008 | 04:49 PM
  #4528
zJatoRad's Avatar
a $15 dollar part can't make up the $60 dollar difference between the Sport and the Race engine. The race engine is.. well, Race Tuned, the carb is different if i'm not mistaken, the crankcase in the Race is black, etc.
zJatoRad is offline
Old 10-16-2008 | 04:53 PM
  #4529
RETRO RC's Avatar
I had to run a rossi carb on my 7port while I was waiting for some new orings to come in stock and I found the same thing, my run time dopped by about 30-40 seconds and the only real advantage was the slightly increased tuning window -but it's got a Go carb back on it now.
RETRO RC is offline
Old 10-16-2008 | 05:57 PM
  #4530
22Racer's Avatar
The 3 port sport is a great motor for the money. ($115.00 is Map) it uses the same crank, rod,piston, block, bearings. The carb is aluminum, head is smaller and the block doesn't have as much milling internally. The sleeve has just basic cuts in it, I modded one a while back and it was really fast. I never really raced it but me and my son were on a 100x60 dirt oval playing around and he had his 5 port and I had my modded 3 port sport. It was pretty much a dead heat.
Rex
22Racer is offline
