Like Tree2Likes
Go-Tech Engines Thread
Old 06-25-2008 | 08:58 PM
  #3391
soccerlaw's Avatar
Hey guys, what turbo plug should I use for a 3 port R on the east coast during the summer months? Thanks,
soccerlaw is offline
Old 06-25-2008 | 08:59 PM
  #3392
skeller's Avatar
P3
skeller is offline
Old 06-25-2008 | 10:53 PM
  #3393
grizz1's Avatar
Originally Posted by vnmsgt
I agree. I have a 7-port in my Caster ZX1-R and it is sick. I only use about quarter throttle on the complete track at the tracks around me. I am thinking of putting it in my K8T and getting a 3 port for the buggy.
7 Ports ROCK - a lot of people under estimate them, silly people
grizz1 is offline
Old 06-26-2008 | 12:10 AM
  #3394
SqueegUK's Avatar
Originally Posted by mugenb46
what type of breakin did you use?
I used the one listed on here somewhere, where you idle 2 on the box (with the heatgun so temps stay above 200F) and then do the rest of the running in gently and rich on a flat road. I must have run about 20 tanks (almost a gallon) before I started to lean it any. It still had tons of pinch on it after this.
The annoying thing is that I babied this engine from the word go. I would'nt start it unless I had my heat gun to it. If I went to the track, I always made sure it sat in the footwell with the heater on it.
My mates LRP he got just before mine had the same treatment and his still has a little pinch on it after 2 1/2 gallons??????
SqueegUK is offline
Old 06-26-2008 | 04:53 AM
  #3395
What clutch are you guys running in truggy with the .25 5 port? I'm looking to try a new set up in my mugen but can't decide if the m2c clutch or the fioroni 2 shoe or the 5 shoe will work best. Thoughts?
mike63 is offline
Old 06-26-2008 | 05:38 AM
  #3396
Dan Reino's Avatar
Originally Posted by Jesussaves
Thanks for the info Dan
Did you have you throttle EPA set 80%
Yea, its close to 85-90%. Saves on fuel milage, and keeps me from blowin off tires.
Dan Reino is offline
Old 06-26-2008 | 06:21 AM
  #3397
aznitronut's Avatar
Whats been the results for .25 Go 6 port? Performance? and Mileage? I've tried the 086, JP1, JP2, Jp3, JP4, 053, and not sure which is giving the best results, This is for Truggy. Have not tried this on the track yet, just out in the street, has about 3/4 of a gallon on it? Temps seem al ittle high, 240- 265 range.
aznitronut is offline
Old 06-26-2008 | 06:36 AM
  #3398
skeller's Avatar
The M2C 4 shoe clutch will not fit the Go engines.....the skirt on the back of the flywheel won't fit over the crankcase.
skeller is offline
Old 06-26-2008 | 07:00 AM
  #3399
How aboutthe fioroni 2 shoe or do I need to stick with the oem mugen?
mike63 is offline
Old 06-26-2008 | 07:03 AM
  #3400
soccerlaw's Avatar
So m2c clutches don't fit on go-techs???? That would explain why I wrassled for about 45 minutes trying to get it to work and ended up blowing some clutch springs as it wasn't flush. It's funny, I actually spoke to M2C yesterday and tried to explained what I did and we joked around about some people are just the kind of people that you could put in a phone booth with two bowling balls and within 10 minutes they would have broken one bowling ball and lost the other!!!
That sucks that it doesn't work though as I heard it's by far the best clutch option out there for 8Ts. So what are you guys with 8Ts running? I'm using dynamite max lifes right now.
  #3401
free2day77's Avatar
All engines rut a little hot during the break in period. After a gallon or 2 temps should stabelize.
free2day77 is offline
Old 06-26-2008 | 07:20 AM
  #3402
Davidka's Avatar
240-265* is perfect. Let it run. Trying to tune the engine's temp down just costs you piston life. At ~250* everything is expanded correctly, they're meant to run that hot. I've got no idea about the pipe though. Run the one that makes the engine run the way you want it to, don't worry about those temps. If the engine is too hot it won't run well, that's how you know it's too hot.
Davidka is offline
Old 06-26-2008 | 07:46 AM
  #3403
yaright's Avatar
I am running the fioroni 4 shoe(turbo twin), with two soft springs on my PTM 25. So far so good, I am sure I will play around with the springs and shoes once the motor is fully run in.
yaright is offline
Old 06-26-2008 | 08:07 AM
  #3404
will g's Avatar
tony
hey i ran a go 2047 with my .25 the other day at the nitro pit and it ran around 280-285 and it ran awesome had tons of power all around may want to try that. i have dyn 053 and it ran ok with it till i stuck on the go 2047 thnx will g see you at the track
will g is offline
Old 06-26-2008 | 08:44 AM
  #3405
Will the vario 3 shoe work with the go?
mike63 is offline
