Go-Tech Engines Thread
#3421
You can use the M2C clutch and flywheel on the Go engines, I have used them for over a year, you will need to shim between the front bearing and the collet, or cone washer if you will, just make sure you get the right size, I think it's 7 or 8 mm ID, and you want it to ride on the inner bearing race and the base of the collet, check the thickness, usually it will take about a 3mm shim, just enough so it does not rub.
#3423
Cheers MM
www.massivemods.com
#3425
I bought an M2C set up in Atl. at the PNB....it would not work on my 5P in my OCM. I talked to the guy after that and he told me it wouldn't work on the Go engines. Maybe it was just in the OCM. To get the flywheel skirt off the crankcase required alot of shims....then the outside clutch bearing was halfway past the end of the crank.
#3426
Looking to get a Go Sport engine http://www.amainhobbies.com/product_...ducts_id/16977. What is the best pipe for a med to large track? This is for a 808.
#3427
http://www.amainhobbies.com/product_...ducts_id/24707
This is an awesome engine!
#3428
Yeah I saw that one. But I want to stay below $200 for engine and pipe. By the time I get my buggy built the season here is almost over. 2 months of racing.
But just a fyi. What is a good pipe for that one?
#3429
#3430
Just tryd out the redline femca 0801..also drop to a 13t from a 14t.
WOW this 3p rspec explodes with this pipe..
hsn 1/4 in from flush.
lsn 1 3/4 in from flush.temps. at 260ish.
Had buggy guys telling me that the have never seen a truggy move so quick.
I am a go engine guy from now on...
Next engine will be a PTM 5 port.
Thanks for all the great info Brain ..you really know these go engines..thats for sure.
#3431
I don't see a pullstart on the Go 3 Port Sport..
#3432
hey guys just wanted to let you know i finaly got to run my ptm .21 3 port race engine on the track last night and was very pleased. although i got a major lean bog on bottom after couple mins running. i then figured out that for some reason it just did not like my pipe i was running. i originally had the go 2047 and it kept choking the motor on bottom so i went back to good old faithful dyn 053 and it ran awesome. temped around 250-260 man i was very happy after that. thnx brian and ptm im very happy with the engine. thnx will g
#3433
I was happy with my GO 7 Port until the bearing retainer clip apparently flew out and bounced around in the engine, destroying it in the process. What causes that and how can I prevent that in the future? Pissed!
#3434
As I said before I just ordered my 1st PTM Go 5 port. A couple other guys at my local track just got some Go's themselves and the older guys at the track were trying to tell me that these mills werent equal to some of the more pricey mills and thats why you dont see them too much at any larger races. And I told them that I did my research before buying 1 and that this over 100 page thread was here swearing by them. Then 1 of the guys told me that everybody who talkes Go mills up works for Go tech or is affiliated in some way with them, I was like yeah right why cant someone have quality products at good prices. I just wanted to tell my expierence today and to say like I always say "there will always be HATERS"
#3435
Where can I get the GO 0801 pipe (INSTOCK)????? Has anyone try the EB Mods pipe on the 3port?? If I can't fin d the GO pipe soon I was thinking about trying the EB MODS pipe on my GO 3port
2Likes
