Like Tree2Likes
Go-Tech Engines Thread
Old 06-25-2008 | 06:27 PM
  #3376
Originally Posted by mugenb46
i would call them gen 4, they have the same design, but the engines available in a week will have the old lsn, this should clear up any hsn issues, it allows a braoder tunning window allowing more fuel to be adjusted with.
this engine is being ran in a xray 808, by team driver Dan Reino, i have been out of town every weekend all summer doing big cars, but him and Jackie Woodard are both on my speed dial, they both run xray, and jackie runs truggy, using a PTM .25
the 7 port is not fully modded, at this we are just going a little at a time trying a few things that may roll over into the full modded PTM engines, so far we are liking the results.
we are running byrons currently but i stongly prefer Tilted 30%, with a P3 plug and the GO FEMCA 0801 pipe, and innovative designs 6mm carb insert, and Dan is running the stock clutch shoe set up that the car came with, all 1.0 with alum shoes. i don't have a clue what his epa's are on the radio, sorry
I will get Dan to post on here in the morning and give his opinion on the feel of the engine to this point, if there is anything he doesn't like he will state it, he is very honest on his input of the engines i provide him, he has done 90% of our testing on the PTM GO engines.
Thanks Brina, I really do appreciate you time and help
Jesussaves is offline
Old 06-25-2008 | 06:29 PM
  #3377
Originally Posted by Dan Reino
This was my second weekend w/ one of Brian's PTM Go Tech '08 7 port, w/ Inovative Designs 6mm carb restrictor, Os P3 plug, Go Tech 0801 pipe and header, Byrons Gen 2 30% fuel.
I AM SO DAMN IMPRESSED!!! Just over 11 min. of run time!! Tons of Power!!!
I have been a Vspec fan for the past 3 years, Bye Bye OS, Hello Go Tech!!!!!
I never ran the older models that had Carb issues, but no problems w/ the '08 it holds a tune very well.
Dan Reino
Thanks for the info Dan
Did you have you throttle EPA set 80%
Old 06-25-2008 | 07:19 PM
  #3378
Originally Posted by vti-chris
A friend of mine wants to buy two GO engines...one for a buggy and one for a truggy?
I own the 3 port R but i'm not impressed from the low end power although it has more than enough power on mid-high end.
-For the buggy i was looking into the new 08' 5 port engine...have they upgraded the carb on this version...is it easier and better than the silver head 5 port?
-For the truggy i need your opinion on the most powerful GO >.21.
As Reino stated, the ProTwister .25 is a good Truggy engine. TMiZZ ran one at Atlanta in his truggy. Great power and fuel mileage was great as well.
Brandon Powell is offline
Old 06-25-2008 | 07:27 PM
  #3379
nuttynative's Avatar
Is there a link to PTM? Tried to google it with no luck. Can't find a home page to Go Technology either. All I've seen are their .21's. Don't like the head color of the 7 port.
Also, any info on the JP4 combo?
nuttynative is offline
Old 06-25-2008 | 07:41 PM
  #3380
vnmsgt's Avatar
Here is a pic of the .25 GO.
http://www.holeshothobbies.com/servl...sh-PORT/Detail
vnmsgt is offline
Old 06-25-2008 | 07:52 PM
  #3381
Default 7 Port vs 3 Port R in buggy
I am currently running a 3 Port R spec in my buggy. I have done some practice on outdoor tracks, but primarily I run on an indoor track during the fall and winter.
How does the low end power of the 7 Port compare to the 3 Port R? I was thinking of trying the 7 Port, but I am afraid the low end power may be too weak on a smaller track. Is one easier to tune compared to the other?
How does the runtime compare between the 7 Port and 3 Port R? I would be running the 0801 pipe.
brianr34 is offline
Old 06-25-2008 | 08:00 PM
  #3382
mugenb46's Avatar
Hi, this is Brian from PTM. The Jp4 is a good pipe on the 5 ports, we ran this pipe on the 3R as well and it didn't work well imo with it. The Jp feels good just abouv the bottom end range and just before the top end cuts out, so pretty much a mid power feel, it was nice having a softer feel on loose tracks, it does work well in this condition, as for JP pipes, the JP3 is mean on the .21's just lacks a bit on runtime compared to the GO 0801
if your use to running a speed, the 7 port may be more to your liking, it has a linier feel compared to the 5 port, the 5 hit's hard and pulls with aggresion, the modded 7 hits harder but still has a smooth feel, and we are running the 0801 on it as well, with a inovative designs 6mm carb insert.
If i can help with anything pm me anytime or give me a ring.
mugenb46 is offline
Old 06-25-2008 | 08:06 PM
  #3383
mugenb46's Avatar
the 7 port is the black sheep of the GO engines, here is a vid of last years PTM 7 port in a prototype OCM truggy, driven by Aaron Bigger, yes it's a 7 port
http://www.youtube.com/watch?v=_SgzMa6jeEo
mugenb46 is offline
Old 06-25-2008 | 08:12 PM
  #3384
vnmsgt's Avatar
I agree. I have a 7-port in my Caster ZX1-R and it is sick. I only use about quarter throttle on the complete track at the tracks around me. I am thinking of putting it in my K8T and getting a 3 port for the buggy.
vnmsgt is offline
Old 06-25-2008 | 08:13 PM
  #3385
skeller's Avatar
I was at that race.....nobody could believe it was a 7P!
skeller is offline
Old 06-25-2008 | 08:14 PM
  #3386
Is there much of a difference in runtime between the 7 Port and the 3 Port R?
brianr34 is offline
Old 06-25-2008 | 08:24 PM
  #3387
mugenb46's Avatar
here is another
http://www.youtube.com/watch?v=OqTqt...eature=related
mugenb46 is offline
Old 06-25-2008 | 08:28 PM
  #3388
mugenb46's Avatar
what are you getting on the 3r now, i was getting just a tic over 10 with mine at times, our 7 port whent 11.15 this past weekend, but Dan is smooth.
mugenb46 is offline
Old 06-25-2008 | 08:31 PM
  #3389
In the video, is that a stock 7 port or one that has been prepped?
Old 06-25-2008 | 08:38 PM
  #3390
mugenb46's Avatar
mugenb46 is offline
