Go-Tech Engines Thread
#1876
#1880
yah my fuel line is all new and should be fine. i am probably going to the track this weekend and will richen it out till i get around 230- 260?
Hey brian also there is a little bit of black goo coming from the front bearing i am thinking it is just the grease in them?
#1881
Hmm, if the bearings is pushing anything out that tells me it is still rich, it could be some of the grease that got cooked at 370
run it in more at the track after you faten it back up, let me know how it goes. just go easy with it for a few tanks and then start leaning it to make some power, just don't go full race tune right away. The motor is still tight so don't kill it by leaning it out to fast
#1882
hi can any one give me some addvice?? my carb keeps moving on my go 21 7 port, i have done the pinch bolt up as tight as i can but it still moves if i turn the card at an angle it goes tight but when and is ok but i am not happy running it at such a angle can anyone help????
#1884
GO Rulez.......I got 3rd at Hot Rods last night was running against some expensive known power house engine.....Would of had 1st but I couldn`t keep it once I got it...Oh well there`s always next time
#1887
Email Russell ......I think there in stock all you can do is Email and see. [email protected] Tell em Justin Dyer told ya.
#1888
He doesn't post here so I figured I'd let you guys know, Chris Pace finished second at the East Coast Nitro Series behind last year's defending champ. After some bad luck he bumped from the B and moved up through the field nicely. Pretty sure he was running a modded motor by Brian.
#1890
2Likes
