Team Magic G4
#8356
thanks
Hi Gansei,
On the fuel consumption question.
Try this,
If motor is still prety new, put head shim to 0.35, 0.36 or so. Also the hotter plug, No:5 should also help.
Try putting a little 'Negative expo' on the throttle. Say 10%. (It all helps)
What can also help is setting the pressure line 3 times the length of the fuel line. Aswell as getting a more even pressure at the tank it can also help with fuel fuel efficiency.
Also, as pointed out. Make sure your car is not changing up to second too early as this makes the clutch slip and wastes fuel !
Hope this helps you and congratulation Gansei on your win sir !!
British Menace
Try this,
British Menace
Do Back pressure chamber help to increase fuel consumption?
#8357
I've never had fuel consumption issues with my CRF and I have a pressure chamber installed on my G4S which, in a way, regulates pulsed pressure coming from exhaust. BTW, I see you put a rubber band for throttle return but CRF has a very strong spring for this job in carburettor boot. Your throttle servo drains too much amp IMO.
Asil
Asil
#8358
ive read some feed back from Cyril and Berton and they think alot of it is in the clutch i belive they run the orion clutch
#8359
Asil
Asil
so i changed rubber band..
#8360
I have agree the key to the CRF is definately the clutch.
Also we found they dont want run properly if tuned conventionally to 100deg/c, they like 110/115 deg/c.
Note though we have run them on 16% nitro so cant compare to 25%/30%
if not using the Orion clutch we used the G4S black clutch as the red one seemed to slip too much.
Gansei search back a couple of months there was a lot of CRF clutch info shared on thsi thread.
What ever i had on my pc was lost since i had my hard drive crash on my laptop and desk top.
#8361
OK Gansei.. I run my CRF 2007 around 120-124 centigrade with %16 fuel and never had any problems. I use k factory black clutch spring but as you stated before it deformed and I've just received Orion square spring and will try it.
Asil
Asil
#8362
2007 - AARCMCC IC On Road Australian National Championships October 23rd - October 28th - my very first nationals event but for some its battle on the best in Australia.... Below is the Pro Tourer Entry List: Also i added in some updated pics of my practice shell and the new engine IDM 2 all broken in - Its a ROCKET very very impressed - cheers PattoJNR
Pro Tourer: - 50 Full
David Arthur
Andrew Bardetta
Ric Bartolozzi
Alan Beven
Paul Borthwick
Chris Callaghan
Scott Callaghan
Darrin Campbell
Paul Capel
Robert Caprile - TOY000 G4S/G4+
David Chen
Jesse Davis
Paul Evans
John Germanos
John Grenville
Kim Gruber
Luke Gunton
Matthew Harris
Frank Hodak-Kodak Hodak G4S/G4+
Peter Jovanovic
Steven Jovanovic
Tommy Lee
Brent Lockwood
Brian Madsen
Ryan Maker
Derrick Miller
Peter Miller
Daniel Morris
Andrew Newham
Anthony Newham
Simon Nicholson
Paul Pattison - Pattojnr G4+
Rhys Piro
Chris Reade
Graham Rootes
Chris Russell
Ben Ryan
Andrew Sensche
Ashley Seward
Brendan Sola
Luis Sola
Wayne Thomas
Thorsten Tophinke
Orson Trowse
Justin Vergunst - G4S
Stephen Wesley
Timothey Westwood
Ashley Whittaker
Clifton Young
Jake Zarb
David Arthur
Andrew Bardetta
Ric Bartolozzi
Alan Beven
Paul Borthwick
Chris Callaghan
Scott Callaghan
Darrin Campbell
Paul Capel
David Chen
Jesse Davis
Paul Evans
John Germanos
John Grenville
Kim Gruber
Luke Gunton
Matthew Harris
Peter Jovanovic
Steven Jovanovic
Tommy Lee
Brent Lockwood
Brian Madsen
Ryan Maker
Derrick Miller
Peter Miller
Daniel Morris
Andrew Newham
Anthony Newham
Simon Nicholson
Rhys Piro
Chris Reade
Graham Rootes
Chris Russell
Ben Ryan
Andrew Sensche
Ashley Seward
Brendan Sola
Luis Sola
Wayne Thomas
Thorsten Tophinke
Orson Trowse
Stephen Wesley
Timothey Westwood
Ashley Whittaker
Clifton Young
Jake Zarb
#8363
David Arthur
Andrew Bardetta
Ric Bartolozzi
Alan Beven
Paul Borthwick
Chris Callaghan
Scott Callaghan
Darrin Campbell
Paul Capel
David Chen
Jesse Davis
Paul Evans
John Germanos
John Grenville
Kim Gruber
Luke Gunton
Matthew Harris
Peter Jovanovic
Steven Jovanovic
Tommy Lee
Brent Lockwood
Brian Madsen
Ryan Maker
Derrick Miller
Peter Miller
Daniel Morris
Andrew Newham
Anthony Newham
Simon Nicholson
Rhys Piro
Chris Reade
Graham Rootes
Chris Russell
Ben Ryan
Andrew Sensche
Ashley Seward
Brendan Sola
Luis Sola
Wayne Thomas
Thorsten Tophinke
Orson Trowse
Stephen Wesley
Timothey Westwood
Ashley Whittaker
Clifton Young
Jake Zarb
David Arthur
Andrew Bardetta
Ric Bartolozzi
Alan Beven
Paul Borthwick
Chris Callaghan
Scott Callaghan
Darrin Campbell
Paul Capel
David Chen
Jesse Davis
Paul Evans
John Germanos
John Grenville
Kim Gruber
Luke Gunton
Matthew Harris
Peter Jovanovic
Steven Jovanovic
Tommy Lee
Brent Lockwood
Brian Madsen
Ryan Maker
Derrick Miller
Peter Miller
Daniel Morris
Andrew Newham
Anthony Newham
Simon Nicholson
Rhys Piro
Chris Reade
Graham Rootes
Chris Russell
Ben Ryan
Andrew Sensche
Ashley Seward
Brendan Sola
Luis Sola
Wayne Thomas
Thorsten Tophinke
Orson Trowse
Stephen Wesley
Timothey Westwood
Ashley Whittaker
Clifton Young
Jake Zarb
if you want more corner-in..
change the front speed bulk cover to plastic parts
i like more plastic parts than aluminum one.
good luck to Kodak Hodak..
#8364
cheers gansei - currently i have new diff in front - before i had spool but i do like the diff as its smoother to drive with 50,000 diff oil and 10,000 diff oil rear!!!
wheel base is reduced in the rear via 1.5mm shorter arms - but this also includes the new improved G4+ flywings front and rear
overal wheel base is now: 254-256 vary on caster front settings
wheel base rear 199
wheel base front 197
i had a few problems again with Spectrum radio in engine break in - had glitch and runaway at low speed broke front bulhead
Again this weekend i will do one more test before we drive 8 hours to the event next week....
this event will be just a taste of what real competition is about, i guess expect nothing and luck might get me somewhere in top 20.... but i think it will a big ask....
i shall have full report once i get back!
As for setup i guess the prac days leading to the event will be critical
wheel base rear 199
#8366
Good luck at the nats guys !!!
Im busy rebuilding for the nats on the 27th.
Have a new puppy thats been broken in for the nats.
#8368
#8369
Thanks Paul. I never drove with a diff before. Should be a good change to have 4wd brakes.
#8370
