Team Magic G4
#6902
Looks like I should spread this out. RC-Mushroom is selling G4S with FREE ED system!! They must selling out this fast http://rc-mushroom.com/product_info....oducts_id=9675
#6904
and rear sus arm length is shorter.
if i do setup front 200m, rear 200mm by G4S Stock knuckle arm.
and i replace with G4+ knuckle arm (same front 200mm, rear 200mm)
sus arm length effect like will be front 202mm, rear 198mm(by seeing point of view stock knuckle arm setup)
then.. front activity will be smooth.. and rear activiry will be quick.
But i did setup my G4S in long time by Stock knuckle arm..
i very suffered after chaging G4+ knuckle arm in FEMCA 2007.
Daz said G4+'s review..
"According to Daz there is more steering and the car is very responsive."
But.. my point of view.. rear is very unstable.. and feel understeer in corner-in.
i quess that my G4S wheel base is 4mm shorter than G4S Stock
and becauise such different factor..
so i could not find proper setup my G4S after changing G4+ knuckle arm
frankly speaking.. my G4S activity was the worst.. in FEMCA 2007
But i could enter B-MAIN (Heat 16th).. it was very fortune result.. ^^
#6905
I agree with you that they are different but unfortunately you didnt have time to get your setup with the quick release uprights.
After i changed myine ,i made sure i check my track width.But genereally we would expect it to be the same when changing to the new parts.
I guess in hind sight we would have to say to everybody to always double check your cars settings when changing or adding new parts.
#6906
I'm happy with my G4S, and since the G4+ is gonna be limited editionI believe its gonna be expensive and hard to get. so I am staying with my g4s, maybe add some g4+ parts.
on a second note, anyone know whats the best traction additive to put on the track?
this is just when we practice, and I don't want to spend too much money on it, here is what I have so far.
1) Clean off the track throughly with the leaf blower, remove as much dust as possible
2)spray on 2 coats of high sugar grape soda, applied with a pump sprayer.
does grape soda do the job? or something? because where I practice it is always very dusty and we need to add some stickiness to the track or else the cars are all over the place
#6907
i experianced many failure by changing option parts..
But i like very much new parts, option parts.
so i did repeatedly the same mistake.
and i can get new setting method(sus arm length changing)
by changing Wheel Hub thickness
it was very useful experience for me...
i have to learn about RC Setup.
i feel my lack of RC knowledge. ^^
#6908
then .. the traction will be good.
and.. setup ride height high and give more roll(soft suspension) in low traction
then.. the car will go well..
#6909
Bud dont rely on the Soda to give you the grip !!!
We use 10kg sugar to about 50/60 liters of water and just spray it evenly with out making puddles.we do 3 rounds with our sugar machine which is a old lawnmower engine with a pump on it spraying out of a 3.5m bar with garden spray nozzles.We use a 200 liter plastic drum for the resevoir and all assembled on a frame with dolly wheels.
The aim of the sugar water is to hold down the dust and add a little to the grip.Ive read on the electric threads that guys add 2/3 2 liter grape soda or Mountain dew etc to the sugar water to help rprevent the sugar crystalising.
As complicated as ive made it sound its simple.
#6910
you are right...
So dont worry we will get it sorted ,just keep asking questions and contributing to the thread
Im going through the same motions of understanding setup.
#6911
Regional Moderator
Hey Darkseid,
Are you racing soon? Do you need them quick like?
The reason why I am asking is that I know Sam at Raceday is expecting a shipment in very soon (I'm presuming he is getting more rear arms in?!)
But if you need them now, I have a set you can have! Just order a set from Sam and have him send them to me. Pm me your address if this helps you.
I'm not racing again until 16/17 June so I'm not desperate.......yet?!.....lol
Hope this helps out.
Menace
Menace
So if its anywhere near as fast from rc-mushroom, then I should be good by this weekend.
#6912
Hey Gansei, Are sure you don't want to go to Jakarta again for DTM ?? to get 18 laps ?? I'm just kidddin......
You are always welcome bro !!!
BTW, don't bother too much with upgrades or hop ups if you don't feel comfortable driving it.
#6913
They give you EMS tracking number, right ?
#6914
REMEMBER,
Keep it simple, keep it FAST!!!!!!
