Mugen MTX-3
Re: mtx set up
Originally posted by gentleman81
i have just got a set up station for my mtx 3.
can anyone give me a setup for a tight technical infield , the track does have one straight but i loose all my time because i cant take any speed into the corner.
running the stock pulleys and one way
dark blue springs all around
2.5 rear sway bar
front bar parallel to ground
stock shock oils and diff oil
also the track is a parking lot track with not the best in traction,
i usually get a push in the turns that make me slow way down to make the turn, but until now i have been playing my settings by eye.
2.5 rear sway bar
small, tight and technical, no grip..... requires late braking on those corners.
Then i'd start again with the basic set-up from Mugens manual, and start dialing whatever correction the car needs on a one to one problem basis.
It is imposible to give you particular set-up that will work like magic...every track has it's mysterys that have to be found.
AFM
If I were you, i'd use a front diff on those track conditions........
Well said, you took the words rite out of my mouth.
i run at a tight technical track. try this setup:
front diff - 50000 oil
rear diff - 50000 oil
camber
front = -2
rear = -4
droop
front = 2
rear = 6
toe
front = .5
rear = -2 (add one if the track is loose)
swaybar
front = flat
rear = all the way to the end of rod
try 37 shore tire all the way around and put 35 in the rear only if the track gets more loose.
good luck and update me if this works
camber
front = -2
rear = -4
droop
front = 2
rear = 6
toe
front = .5
swaybar
front = flat
i forgot the ride height
front and rear = 5
do 5.5 ride height when the track gets more loose
let me know how your car reacts after doing this setup and you can do more changes from there.
front and rear = 5
thanks for the info
i set it up to spec with the mugen sheet i got online. i have to get the parts to assemble my front diff and then i will try it. so .5 toe in the front is wnough huh, i'll try it, i always thought it was 1-2 deg? any way if the weather permits i will take my newly tuned mtx out to give some a$$ kickin on sunday i will keep all this info close by.
Robbie
At the weekend we suffered a lot of traction roll (rear end) due to the high grip and high temps.
We tried a lot of different set ups during the weekend to try cure it but it never completely went away.
In the end up we were running the following set up which seemed to help the most.
Rear:
40 shore tires
Purple springs
30wgt oil
Rear Pistons 2 hole 1.1mm
Rear Diff 30k Mugen Diff Oil
Rear anti-sway bar standard setting
shocks in top holes
5deg camber on rear wheels
3-4 deg toe-in
A blocks
Front:
42 shore tires
Light blue Springs
30wgt oil
Pistons 1 hole 1.3mm
Solid Front Axle
Anti-Sway set hardest
Shocks in top holes
3.5deg camber
2deg toe-out
0 caster
Traction roll was still a problem. Any idea what we could try to get it cured as the next track will be the same conditions. hardening the car up made it worse.
Rear:
40 shore tires
Purple springs
30wgt oil
shocks in top holes
3-4 deg toe-in
A blocks
Front:
42 shore tires
Light blue Springs
30wgt oil
Solid Front Axle
Shocks in top holes
3.5deg camber
2deg toe-out
0 caster
Re: Robbie
Have you tried C blocks in the rear?
Re: Re: Robbie
Y dont u try overstear setting. Set d car hard at rear and soft at front. Hope this will help. Regard.
How about lessening the rear toe?
1.5 or 2 degrees should do.
high tracktion set up
Recently ran in local state titles
Very high tracktion smooth track sprayed with VHT
Here was set up used
Rear:
Mugen Fast tyres 42 shore tires
grey springs
60wgt oil
Rear anti-sway 2.5mm 3mm in from end
shocks 2nd hole from bottom
4deg camber on rear wheels
2 deg toe-in
3mm spacers on top of hub
A blocks
Ride hight 5mm
Droop 6mm
Front:
dark blue Springs
60wgt oil
1 way Front
Anti-Sway set softest flat
Shocks in bottom
2camber
0.5toe-out
caster 2mm spacer in front
A ackerman
Ride hight 5mm
Droop 3mm
16 19 conversion Mugen pulleys
Rear:
grey springs
60wgt oil
2 deg toe-in
A blocks
Ride hight 5mm
Droop 6mm
Front:
dark blue Springs
60wgt oil
1 way Front
Shocks in bottom
2camber
0.5toe-out
A ackerman
Ride hight 5mm
Droop 3mm
Kawahara Tires
Hi guys
Can anyone tell me where I can buy 1/10th Kawahara tires from, I'd like to try them but don't know anywhere that stocks them.
Re: Robbie
Rear:
40 shore tires
Purple springs
30wgt oil
shocks in top holes
3-4 deg toe-in
A blocks
Front:
42 shore tires
Light blue Springs
30wgt oil
Solid Front Axle
Shocks in top holes
3.5deg camber
2deg toe-out
0 caster
Rear:
40 shore tires
Purple springs
30wgt oil
shocks in top holes
3-4 deg toe-in
A blocks
Front:
42 shore tires
Light blue Springs
30wgt oil
Solid Front Axle
Shocks in top holes
3.5deg camber
2deg toe-out
0 caster
try 56 or 57 mm size tires thats what they run last nats at ohio
If you still traction roll with smaller tires, try gluing the sidewalls.
