Mugen MTX-3
Originally posted by gonzoY5
Mike, I'm using the B over in Royal Palm. Gives me plenty of steering.
The A works best at the Royal Palm. But use the B, I don't want you getting too fast out there
Are you going out on Sat for the seminar? Ed's going to explain a bunch of things that you'd prolly be interested in.
I've used the Eagletree recorder with my electric cars but not with my Mugen yet.
It works great but with a 2 speed, you have to figure engine speed for one of the gears in Excel. It would definately be useful to see where your chutch engages and what RPM the car shifts at.
They also have a telemetry unit in the works.
Just to clarify, B for steering and A for rear end?
Originally posted by alucard13
I am planning on it. I need all the help I can get.
i use b and c and cut the rear hubs down and run rubber tyres
build it as kit!! and try the differant ones for your self
Originally posted by Cartman
what do you want your car to handle like?
....................................i cut the rear hubs down and run rubber tyres......................
AFM
I run at Royal Palm and Palm bay. Royal Palm is a nice sized track, whereas Palm Bay is a little tighter. I want something in the middle to i can worry about toe in/out, camber, caster, etc. and not about the servo saver and rear end.
The problem is that something in the middle will not work as well as you want on either track. I guess stick with the A ackerman in front so you'll have all the steering you want. And then just experiment with the rear blocks, they're not really that hard to change out. But A in the rear works MUCH better at Royal Palm
Big Apple Race Date Added This Coming Sunday 7/25/04!
The Race Site is located @;
Middlesex County College
2600 Woodbridge Avenue
Edison, NJ
Hope to see you guys there!!!
Edison, NJ
I've been using the GPM uprights all year, and haven't had the first problem with them. Been looking for the rears, like a fool I sold the rear uprights to Grinder, and have been wanting to get them. Thanks.
Oh and use A front and A rear.
rear block...
i've been following the discussion about the steering a,,b,c thing and also on the rear block a,b,c thing...
i think i understand about the steering block....but on the rear block thing can some one explain simply to me....thanks
A= twichy/aggrasive
b= little smoother/less aggrasive
c= smooth
A steering block is the least amout of accerman smother and gives you less steering
B steering block is middle about of accerman and smooth and gives you more steering.
C steering block is the most accerman gives you the most steering and is the most aggressive.
keith
B block is for semi smooth tracks gives you a little more traction.
C block is for ruff tracks gives you the most traction.
I usually start with the B block and go from there.
keith
