Mugen MTX-3
same goes 4 me
set up board
i have a set up system but i dont have a board yet, what does the board allow you to set?
Re: set up board
thats all just the width of the car and a flat surface?
Re: set up board
back in the old days, you can use it along with the ruler to adjust toe-in/toe-out on cars.
Re: Re: set up board
Nice to see you back, ed.
masaharu
masaharu
when you all are measuring droop in the rear of the car, do you go off where the front pivot ball is or the back one? What do most people run it at?
Toster,
Most measure off the rear pivot ball. As far as how many mm of droop to run start with stock set-up 5-6 mm and tune from there.
tires
anybody here run the elligi technics tires?
how good are they?
help pls
how good are they?
help pls
DB Racing Belts
hi guys
for those of you who need 16/19 belts i have them on the for sale thread and here's the link:
MTX-3 16/19 side belt
for those who bought from me before, thanks for your support!
Re: tires
how good are they?
help pls
how good are they?
help pls
i personally like monotuning tires. no glue problems and strong rims.
mtx set up
i have just got a set up station for my mtx 3.
can anyone give me a setup for a tight technical infield , the track does have one straight but i loose all my time because i cant take any speed into the corner.
running the stock pulleys and one way
dark blue springs all around
2.5 rear sway bar
front bar parallel to ground
stock shock oils and diff oil
also the track is a parking lot track with not the best in traction,
i usually get a push in the turns that make me slow way down to make the turn, but until now i have been playing my settings by eye.
2.5 rear sway bar
Genltleman81,
First your car should handle alot better once set-up properly on your new set-up station. Without knowing track conditions and layout I can make afew suggestions.
- more front toe-out(turn in harder&more agressively)
- thicker rear diff silicone(drive harder into first portion of turn)
- add front camber(alittle goes a long way)
- lower front ride height in relation to rear
The list can go on and on but this is a good starting point.
Remember your always going to have to slow a bit in the turns, so dont try to overdrive the car. Also what shore tires are you running?
i usually run a 35 or 37 shore, because the track is not that great and is very slick this time of year. out of the setup sheets available on mugens sites which would be the best starting point?
