Mugen MTX-3
Old 07-08-2004, 08:33 AM
  #13231
Default Re: diff parts
Originally posted by
where can i get the front inside parts for my diff in my mtx3 the kit comes with the housing, are the front and rear diffs the same inside? and what oil should be used for a parking lot track with some tight turns and a low bite surface?
and do i need anything else to run a diff up front in this car?
gentleman81,
I picked up diff parts from Ashford hobbys. Robert got me all the parts I needed. I notieced on ebay you an buy a rear diff and use the parts from it.
As for diff oil, on a small track 10000, but try 50000 or 100000 and see if you like drving with that. Will give you lots of braking power...
vadn1 is offline
Old 07-08-2004, 09:39 AM
  #13232
Bandeira's Avatar
Originally posted by Slotmachine
I would try a stiffer oil; try 800 wt. stiffer springs, I used 1/8th. pink rears on the front of my mtx3 at the biggie with softer rears like stock. Try more camber, 4deg. in the rear, 3deg. in the front, you can also try slowing your servo speed down so the car wont be so twitchy with your radio input.Also try a stiffer sway bar.
The track here Is wuite bumpy... The further I can go on the thick side is 600wt I'll maybe use some white all around... or maybe the pink...
I don't think the probelm is on the servo speed as when I have the rolling probelm is a section where I am veeery smooth... Sway bar stiffness is on the max...
Bandeira is offline
Old 07-08-2004, 09:40 AM
  #13233
Bandeira's Avatar
Originally posted by rjl
I broke a front shock shaft after traction rolling in a state final once, the traction rolling problem went away immediately. Lap times went down but.
Last race I broke the rear axle bearing!!! apart from lots of wings...
Bandeira is offline
Old 07-08-2004, 08:49 PM
  #13234
gentleman81's Avatar
so besides the front uprights are these parts that should be carried as spares?
gentleman81 is offline
Old 07-08-2004, 09:35 PM
  #13235
theRED5's Avatar
Hey Bivens, you guys coming down this weekend to run the new layout at the Sugarbowl? The new layout is killer, and it's the 1st race of a summer series AROCC is putting on now that we're renting the track.
Hope to see ya there!!
theRED5 is offline
Old 07-09-2004, 02:11 AM
  #13236
over gear's Avatar
Trader Rating: 18 (100%+)
Can anyone give me an idea where to mount the Orion LCS transponder? room is tight!
over gear is offline
Old 07-09-2004, 02:00 PM
  #13237
on the kit mount!!! or if you run a saloon shell cut a bit of lexan to fit over the front body posts and hang it just above the bumper
Cartman is offline
Old 07-09-2004, 11:14 PM
  #13238
Can someone tell me the difference btwn the old Mtx-3 fuel tank and the new fuel tank...
vadn1 is offline
Old 07-09-2004, 11:19 PM
  #13239
over gear's Avatar
i'm using the battery switch... so i can't use the kit mount for transponder....
the wire to the transponder is not long enough to reach the front body post
  #13240
FW-05RR's Avatar
anybody own the prospec
FW-05RR is offline
Old 07-09-2004, 11:46 PM
  #13241
embed it flush with the front foam bumper
RC Dumb is offline
Old 07-10-2004, 01:13 AM
  #13242
Sacker's Avatar
Default Mugen OP Chassis and pipe
more info
Sacker is offline
Old 07-10-2004, 03:39 AM
  #13243
yes you can, you can fit them both if your clever!! turn one upside down
Cartman is offline
Old 07-10-2004, 04:01 AM
  #13244
rjl
rjl's Avatar
The tank lid is different and is available as a spare part. The tank itself is the same.
rjl is offline
Old 07-10-2004, 06:27 AM
  #13245
rattlr2's Avatar
put front diff in my mtx3. every time run it leaks is this normall or is somthing wrong
rattlr2 is offline
