Mugen MTX-3
Originally posted by rattlr2
put front diff in my mtx3. every time run it leaks is this normall or is somthing wrong
Rattlr2,
I run a front Diff with 50,000 and this past friday night it was leaking. I filled it up as instructions stated. Dont know if this is normal, I will disassemble the front and check out the diff, see how much fluid has been lost.
thanks cartman will give it a try any suggestions on weight in front and rear diffs running parking lot no traction aid
rattlr2,
10k rear and 30k front. If that is still too much then try 5k rear and 10k front.
Turnbuckles
I just completed my MTX-3 Prospec and was wondering what tool you guys use to adjust the turnbuckles.
It's a little bigger than the usual lunsford wrench i normally use. I tried some needle nose but i can't get a good grip on them.
thanks in advance
thanks in advance
Re: Turnbuckles
thanks in advance
thanks in advance
take a cut off wheel and re grind your lunsford wrench mine works fine
First race
I am having my first race tomorrow with my new mtx3 , and it seems to look well and handle good except in tight turns, it wants to do a 360 and whip the tail end around what dont i have set right? i am racing on a parking lot track and i am running the full stock set up and parts what do i need to do to the suspension to get it to have more rear end traction?
might i have the rear to narrow?
also when i brake the tail end does the same thing do i have them too hard?
thanks
thanks
Make sure you dont have the upstop or downstop screws in.
WAY TO HARD IF YOUR USING THE FRONT ONE WAY
Adjust your maximum braking to where it does not lock up the tires
wont that mean that im gonna be crashing into the ground with my chassis and loosing traction anyway?
Re: also when i brake the tail end does the same thing do i have them too hard?
thanks
Re: Turnbuckles
thanks in advance
thanks in advance
Looks crappy but does the job.
If you get stuck pm me and I'll send you a pic.
a small allen wrench is what i use, the L in the wrench helps get to the whole when its in a odd place.
Yeah it's similar. Except I put a kick on the other end so it's easier to turn.
