Mugen MTX-3
#7246
Manti,
How's your Nova MAX going?
#7247
Originally posted by RClover
Manti,
Manti,
#7248
Originally posted by Manticore
havent run it yet, i need to move on to a bigger track to test the engine
shot me some pix, external and internal as well..
#7249
#7250
Originally posted by EVOLUTION
Why,isn't your 60 metre track good enough,or do you need one like this?
#7251
send it over..i'll do free for you as we have BIG tracks here..
#7252
tigher is always better
#7253
I hear that wd40 also makes a good traction compound for the tight tracks!!!
#7254
a can of coke will do the all the traction job for me..
#7255
Originally posted by V-1-R
is there a way to prevent the damper diaphragms being popped in? i notice this each time i open the shock cap? and when its popped in, the shaft doesnt extend fully when compressed.
is there something wrong with the diaphragms? or anything?
thanks
thanks
#7256
Originally posted by Cartman
The diaphram is not there to pust the shaft back out, if it does this your shocks are built wrong. the diaphram is there to allow the movement of oil as the pshock shaft moves into the shock. if the piston/rod is forced out when compressed then there is resistance when you compress the shock giving inconsistent settings
so are shocks shaft supposed to extend fully automatically after i applied force to it?
I built the shocks according to the manual but i am afraid i'd missed out some important steps. Pls do a quick run through of the shock building steps, will ya'? thanks
#7257
thanks
thanks
#7258
the original purpose of the diaphram is for volume compensation just like what cartman said. However, the tension of the diaphram has become tuning tool. you need to be cautious on equal internal pressure of left/right shocks. if your car's handling become weir suddenly especially in the rear, it could have been one of the diaphrams either left or right shock has deformed which causes unequal pressure and rebounce.
#7259
what % fuel should u use when breaking in a engine is 18 % ok
#7260
