Mugen MTX-3
#2476
Just in!
Team Osaka Graphite Rear Body Mount!
Check it out in the Special Section!
Very Limited Quantities!
More exciting products soon!
JustRC
JustRC
#2477
Originally posted by click, dublin
A small bead of silicon sealer is absolutely necessary, its just not a very good design!!
All the best
All the best
#2478
Originally posted by darthkir
I stopped the diff leak by using CA. I glued the diff case together.
#2479
Originally posted by Advanti
how would you change the diff oil ? or you buy another set of the diff?
#2480
its pretty quiet here today...
#2481
It can be pulled apart with a plier.. I only glued around the portion where the two diff cases met. It only leaked through there, as for the screw, I changed them to a longer and wider head. Dont use the stock screw. If you screwed in too much they will damage the hole.
you not real are you?
As for the type of silicone get RTV its oil resistant
#2482
It's true, and it's working. Try it.
#2483
Front end loose
i read about adding spacers near the front axle/ oneway sometimes back where the front end being a little loose.
Could anyone refresh that for me?
#2484
Universals
You guys that are breaking universals if you don't hit S--T they wont break end of story!!!!!
#2485
timmugen your right if i never touch a wall again the universals will never break
thank you so much you have solved all my problems you must be some sort of RC god its a miracle
i never thought about that if i didnt wreck they wouldnt ever break duh stupid me
but wait hold on im not perfect yet and i hit boards sometimes what can i do?
maybe i should stop racing because everytime i wreck a universal could break
or maybe i posted it to see if anyone had the same problem and what they were doing to fix it to get ideas on how to fix mine because i do make mistakes
i used to have a mtx2 it was really nice sometimes i would wreck it too but oddly in 2 years it never broke a universal maybe that could be why i thought something was wrong
nevermind i guess i have to go practice in some really big wide open space so as to get better and not wreck anymore
unless someone else knows a way i could possibly fix the problem
#2486
Maybe you should go get a Serpent car a you won't have anymore problems
#2487
you really think so
i mean so far youve been 100% right
where can i find one for free you can work a miracle for me again right
#2488
Hey Jason,
Dont take this one the wrong way but heres a good practising tip to stop you hitting the boards so much and it will improve your driving really fast too.
Richen out the engine a full turn so the car isnt going flat out. Now drive around the track for a couple of tanks like this. After a few laps you will soon find your able to stay in the middle of the track or near the racing line. Now lean out the engine a 1/4 turn and repeat.
By the time you get the engine back in the turn you should be able to run that same line a lot more consistent and you shouldnt be hitting the boards as much.
Hope it helps
Hope it helps
#2489
Try turning down your dual rate, this will decrees the chances of breaking dog bones. Less through sometimes helps.
Jason I've broken two of the universals, and yes we all do still crash.
#2490
Originally posted by modellor
Hey Jason,
Hope it helps
Hey Jason,
Hope it helps
