Mugen MTX-3
#3976
Re: Re: Re: Re: Kawahara Heatsink..good?
Originally posted by Jack
Rclover
it does reduce heat abit better than the normal heatsink
but not to that extent of 20 deg.
maybe plus minus 10%of actual temp
Rclover
#3977
sway bar questions
hi, despite the cost, what would you prefer on the rear sway bar between kawahara and 3racing ? are they both adjustable...
#3978
Originally posted by RClover
is this the heatsink that can reduce heat as much as 20 deg..?
i would say average is 5'c or may get down to 10'c max
#3979
Re: sway bar questions
#3980
performancewise, definitely kawahara. it is all about R&D. obviously Kwahara does R&D much better.
3racing sway bar problem is that it has too much slop and very little effect on adjustment. their rear sway bar is just too soft even with their hardest setting.
#3981
Re: Re: sway bar questions
Originally posted by Corse-R
Definitely Kawahara: 3Racing is too long and develops a lateral play that is quite annoying.
#3982
Originally posted by Manticore
costwise, they are both similar consider that you need to buy the cross member for 3racing sway bar/
#3983
Hi Traction Tracks
Had a chance to race my MTX-3 this weekend at the the Midwest Series Race. Man is this thing fun.......but not until Dennis Ritchey turned me on to the right body. Thanks to his help all weekend I had a really fun outing. I had bought a prepainted HPI Afla Romeo body. The traction at the track is HUGE. Many cars were traction rolling all weekend. We race on foams and I was watching a fellow racer who was doing well all weekend, and just couldn't figure why my car wanted to roll over so much more than his. I was practicing and Dennis could see my frustration. He put his Older style Stratus body on my car, and the problem was solved. Body's make a huge difference!!! Car was a pleasure to drive.....and I'm staying away from the Alfa body......wwaaaaaayy to much front traction....car was to unbalanced. The Stratus just balanced the car so much better.
#3984
Re: Hi Traction Tracks
If you plan to race, simply don't waste your money on strange bodies and stick to the ones that work: Stratus, Stratus 2.1 and Opel Vectra.... Alfa has too much steering for the actual cars.
#3985
Rayj, how did you like the bumps? Just wait untill the Great Lakes Challange, the traction really get high.
Has anyone had problems with breaking the CVA's in the front and/or ejecting front dog bones? I put ~1/8" tubing in the drive cup, but it still ejected. All I have to say is that this car is still a blast with 3WD.
#3986
BTW: won those final by one full lap.
#3987
Re: MTX-3 & Wet weather
Originally posted by click, dublin
Hi Guys,
Had a bad day today at the first round of the MMAI national championship.
It rained VERY heavy throughout the day, the rain was hopping off the ground about 2 feet!
We ran our cars in between the showers.
First I lost a throttle servo, then I had a problem with radio glitches, water in the receiver!
Then my two speed started to act up going down the straight it sounded like it was attempting to go into 2nd then drop out then back in, out, in etc.
I did manage to keep ahead of a 2003 SMP Slide for about 4 laps . . . he was on foams & I was using wet weather rubber!!
Any ideas on the two speed?
All the best
Hi Guys,
All the best
#3988
the Mugen CVD is a very good investment for your MTX3. I think the main reason for your wheel flied off is the plastic hex adaptor. you should get a set as well.
I broke a dogbone some time ago, finished Final-A of a local race in 3WD from minute 27. Most shocking was when picked my car from the track, the dogbone and the outdrive was missing... Mi pitman said that broke on minute 27 and seeing the lap by lap I wasn't too much slower.
#3989
Re: Re: MTX-3 & Wet weather
this is a bad 2speed clutch nut that i am talking about. look at it carefully for the deadspot.
#3990
Rear diff casing..problem
just how tight the 4 diff screws they needed to be tightened? when i fully tightened, the planetary gears seem locked up and hard to turn even with hands with 10K diff oil. If back out 1 turn on each screw, the diff acts normal but when fitted on the rear block, these screws rub against the rear tower.
something is wrong...
Could it be the wrong screws that i am using? the diff is now with 3 x 12mm screws.
