Old 04-25-2006, 09:45 AM   #4486
Does someone know a good track around Seattle WA? I am currently running in a very small track in West Seattle but it is not in good shape and I would like to try my car in a bigger circuit.
Thanks in advance for the help.
TomiRC is offline   Reply With Quote
Old 04-25-2006, 11:47 AM   #4487
kidDynomite's Avatar
Just wondering if any of you are running a Sirio EvoIII in your MTX-4?
I found that the carb slide's set screw nub hit's the back-angled part of the fuel tank. I actually had to grind some of the nub and set screw at an angle, as well as, turn the carb slightly to the right so that it will clear that part of the tank, but only by about 0.5mm.
kidDynomite is offline   Reply With Quote
Old 04-25-2006, 01:04 PM   #4488
asw7576's Avatar
Need a photo man......
Old 04-25-2006, 04:06 PM   #4489
Speedbug's Avatar
Yes, have the same issue, but opted to grind a notch out of the radio top plate instead of the carby, but also have to have it on an angle.
Awesome motor, it's a shame you can't get back up support or parts for them. especially the cranks.
Speedbug is offline   Reply With Quote
Old 04-25-2006, 04:41 PM   #4490
itchy b's Avatar
you sould try contacting kellets hobbies in liverpool,sydney nsw in a week ore two, they are the new importer for sirio engines and should have a lot of backup parts in stock by then
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-25-2006, 05:12 PM   #4491
Speedbug's Avatar
Yes but are they going to honor all the parts to be replaced under warranty from the engines that are already out there????
I am owed 3 cranks from engines that have had no more than 2-3 litres of fuel through them.
Old 04-25-2006, 07:31 PM   #4492
itchy b's Avatar
only way to find out is to ring and speak to garry kellet about it
EX1.5-SC10 4x4
Old 04-25-2006, 08:08 PM   #4493
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
novarossi based and sirio engines have problem as you mentioned, that's why i run OS, it fits perfect without the need for modification.
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 04-25-2006, 09:35 PM   #4494
Speedbug's Avatar
Have just bought a couple of STS engines to see what the are like.
On paper they have similar performance to the OS but are much cheaper.
From initial impressions they seem very quick, not as quick as Nova or Sirio, but plenty quick enough for our car park track. We have a race meeting tonight which will be the first for the new STS, so i'll let you know how it goes.
Old 04-25-2006, 10:04 PM   #4495
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You chose your engine based upon the fit? You know we are talking about grinding maybe a quarter of an inch off the top deck.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-25-2006, 10:07 PM   #4496
banky71's Avatar
scott.... do you have a baseline setup for the MTX4 for Revelations? If so, could you PM me the setup..... a bunch of us from vegas are heading down there this weekend.....and I would like to know where to start.
banky71 is offline   Reply With Quote
Old 04-25-2006, 10:49 PM   #4497
I wish I did. Robbie told me he has a good setup for Revelation. I will try and get it if he doesn't see this and post it. I know you need hard tires cut very small. He told me 45 shore all the way around and if I remember cut to like 55mm and 57mm. No suspension travel in the front with the front sway bar straight up and down. I will see if I can get the whole thing from Robbie.
Old 04-25-2006, 11:29 PM   #4498
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
I Emailed them about a week and a half ago and still have no reply. Iam not knocking them yet but its not exactly a good way to start to try and rebuild Sirio's name.
Daniel
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 04-26-2006, 07:12 AM   #4499
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default rev set up
u will definately need to put a groove in the front tires. or cut some rubber of the inside edge usually 2mm works.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-26-2006, 07:17 AM   #4500
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Cutting the inside of the tire off can cause it to get twitchy down the straight away. Last time I was there, I cut 2 grooves in each front tire, glued the edges, they were cut to 57mm and the rears were cut to 59. Blue springs all around, 40 wt in rear socks 600 in front, front shocks all the way down, rears in the 3rd hole up. Front upstops set with 1.5mm of travel. Droop, 1 and 5. Camber 2. Caster, 1mm. B blocks all around. The car was very fast.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
