Old 09-03-2006, 01:45 AM   #5986
chippy's Avatar
Originally Posted by itchy b
has anyone had a problem with the diff leaking from the outdrives?
my diff has this problem and the casing is near new
the out drive do have 1mm movement in and out.
should i put extra shim or 2 to eliminate this movement between the inernal gear and the Oring?
cheers
joe
I actually shimmed mine on the out side, between the bearing and the drive cup
Because when I shimmed inside it raised the pin and made the gears bind.
chippy is offline   Reply With Quote
Old 09-03-2006, 02:16 AM   #5987
itchy b's Avatar
thanks chippy, didnt think of shimming outside ,makes better sense.
i tried shimming under the pin and like you said it bound up the gears a bit.
looks like plan B goes into action
thanks again
joe
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-03-2006, 03:27 AM   #5988
wallyedmonds's Avatar
the rear diff never had a prob just tighten it down good with a new seal every time you take it apart,the front i do use silicone to seal it.but i dont use a front diff anymore.and dont shim the diffs they need to move.
wallyedmonds is offline   Reply With Quote
Old 09-03-2006, 03:34 AM   #5989
Originally Posted by rai13
Newb questions here.
How big of a gap should the two speed halves have?
When adjusting the two speed do i have to turn both 2.6x12 screws? At what increments?
And what increments are you adjustiing the clutch spring (engine). And how are you doing it without the mugen adjustment tools.
thanks in advance.
rai
just a hair very little gap and the two 2.6x12 screws ajust the same at 1/4 turn incrim, they have to be the same,this is very important just like your clutch and it takes time to get it right but youll get it.
Old 09-03-2006, 03:35 AM   #5990
Originally Posted by Scott Fisher
They are the same size. They "cheat" on the pitch in order to make the gears the same size. This allows you to change the spurs without having to adjust pinions as well.
this is so true but very cool.
Old 09-03-2006, 05:24 AM   #5991
smostyn's Avatar
Trader Rating: 9 (91%+)
Can anybody tell me if the front diff from MTX4 will fit in to a MTX3????
Thanks for the help.
smostyn is offline   Reply With Quote
Old 09-03-2006, 05:48 AM   #5992
Corse-R's Avatar
This has been asked in so many forms, but we'll answer just another time:
The internal parts of the front diff on the MTX3 & MTX4 are interchangeable, the unique parts that aren't interchangeable are the diff cases, each car has their own and aren't interchangeable between them.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-03-2006, 05:56 AM   #5993
Corse-R's Avatar
cheers
joe
The diff leaks fluid if is filled too much. Diff shouldn't bind or leaks too much if:
1. - Installed the o-rings that goes on the outdrives and put the shim that presses it on the casing.
2. - The diff has the paper seal between the two cases. If the sealing paper isn't there, the gears bind so badly that diff is almost locked and they need to reseat another time and they'll have a very hard time doing them, meanwhile the diff will be inoperative until the gears wear.
A little of play on the outdrives is acceptable. This play is needed to make sure the pin that holds the satellite gears grab hard on the outdrive. Shimming on the outside makes the diff prone to fail by the locking pins on the outdrives.
Cheers,
Corse-R
Old 09-03-2006, 06:28 AM   #5994
itchy b's Avatar
thanks CorseR,
maybe being overfilled was the problem after all, as all your other points was how i originaly built the diff
cheers
joe
EX1.5-SC10 4x4
Old 09-03-2006, 09:22 AM   #5995
just breaking in new engine, if clutch is engagin late, do i loosen or tighten clutch spring??
by the way i only got 1 washer between the thrust bearing and the plastic part, (should have 3) would putting 1 more solve my problem??
thanks in advance
bigboss is offline   Reply With Quote
Old 09-03-2006, 11:18 AM   #5996
Corse-R's Avatar
thanks in advance
If your clutch is engaging late (needs to rev so much) you need to loosen the spring collar (try 1/4 of turn and if bogs, tighten it 1/8 of turn).
In cold conditions, your clutch need to slip a little. Do around 3 laps to your track before trying to adjust your clutch. Clutchbell should be warm to hot to effectively adjust the clutch spring tension.
Cheers,
Corse-R
Old 09-03-2006, 11:40 AM   #5997
thanks for advice
i loosened it, about .6mm now
still need alot of revs to get it moving
my theory is that its running really rich, but aint 100% sure
Old 09-03-2006, 02:14 PM   #5998
Chris West's Avatar
Send a message via MSN to Chris West
thanks CorseR,
cheers
joe
fill to just above where the 2 spidre gear shafts cross, my mate was told at the pre-worlds that silicon oil expands slightly when it gets hot.
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 09-03-2006, 08:13 PM   #5999
i still find the thing leaks,had the prob with the mtx2/3 but i just run the one-way now so it dosent matter.
Old 09-04-2006, 01:21 AM   #6000
always change the rubber seal when re building it. clean it up after the first full day of use with metho (from the outside) this way you can see if it keeps on leaking.
TomB is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
