V-ONE S Thread
#2926
Originally posted by squizzytaylor
It was $38.80 from Southern Cross Hobbies, the big advantage of this is that the output shaft has a ball race in it, it just smooths the action out so much!! I also bought for $24.50 a complete gear set for the diff, There were actually enough gears to rebuild 2 x v-one-r diffs (thats 4 x v-one-s diffs).
gt
gt
U can add the extra gears to the S for stiffer diff action tho cant you?
Maybe ill just wait a while and get the front one way and the blue diff for the back at the same time
#2927
gt
#2928
Oh ok, well when I get a front one way ill put the gears in the back.
Also about a new engine do u think for medium level competition the Novarossi CX12PS2 would be fine, cos I really dont wanna go to rear exhaust/starter box, mainly for cost reasons but also for convenience I guess.
Also what parts do u need to convert to a new engine, was it engine mounts and flywheel?
#2929
Originally posted by Team_Akina_1
Does anyone know if the Kyosho Special engine mount is for PS or Non PS engines? Anyone has any spec of the engine mount for Pull start engine? I need to know the height of it. Thanks
Heres where it gets funny, I can not find a "special" engine mount any where! However........
Kyosho VZW029 low height engine mount will lower the engine by 1mm. (therefore 15mm)
Kyosho 39649 Heat sink engine mount is a std 16mm mount.
They are both listed for v-one-r/rr
gt
#2930
In my S manual, it does have a special engine mount
#2931
If so IMHO the Nova is really as good as it gets. There are heaps of other engines around the 1hp mark but none so tuneable/reliable/indestructible as the nova.
You will need an FD49 Flywheel, and engine mounts to mount the new engine and a new linkage set-up (I can help you do this with diagrams etc) And a tuned pipe capable of delivering that power.
You seem overly keen on a front one-way, Im interested as to why?
gt
#2932
How old is your manual?
gt
#2933
Im only running off memory there, i'll go and dig it up,
dont ask me how old it is.
#2934
Part Number 39648: Special Engine Mount
Part Number FD49: FlyWheel CZ
Part Number 39673: Vespel (Registered) Clutch Shoes
Use togethor for O.S. Engine.
#2935
39648 supercedes to 39649
FD 49 is the same
39673 supercedes to UM210
That being the case the special engine mount is actually the heat sink engine mount I referred to earlier and is 16mm height.
It is of course suitable for both pullstart and non-pullstart engines.
gt
#2936
Well, i think my book is the 2001 version
thats what i went off,
i dont know where the date is, but their is some japanese bull crap and then 2001.
so yeah.
so yeah.
#2937
so yeah.
chek this
the new plan for the new RR http://www.rctech.net/forum/attachme...&postid=357357
so yeah.
chek this
#2938
Im down grading from TR12 to hpi 12r ss. Giving the car to my older brother, however I need new mount for the engine in order to clear the pull start. Taylor, can you give another part number, both part number came up to nothing on tower!
#2939
They are the only numbers Ive got.......I can however tell you that Tamiya TG10 mounts will also achieve the same goal.
gt
#2940
Thank you very much!!! I was thinking of using the TG10 mounts, in fact, that was the next question I was going to ask. Thanks for your help!
