Kyosho v-one rrr
#8956
Right decided to bite the bullet and get a real RRR and sell my old v-one-r, least now i'll have an upto date car, could pass on this car that came up fairly cheap.
However i'm looking to get an all over hex screw kit for it, but can't seem to find one anywhere, I had a stainless kit on my voner, but the the heads kept rounding easily, and they seemed soft.
So i was after a hardened steel kit really, like i've seen on some of your cars, or like the standard G4s, any idea where to order from, and how much $/£ am i looking at?
#8957
https://www.tonysscrews.com/displayP...5&categoryId=2
#8958
Originally Posted by jag
Don't forget that you have been running the Mugen with a lola body and the Kyosho with a TC body. You may find that has something to do with it. What are you using in the front (one-way, diff, solid) of the Kyosho?
From what I have seen and driven, nothing turns like a Kyosho. Around here, you will never hear a Kyosho driver say, "I need more steering".
Another thing is, that the track I run on is far more technical than the tracks you guys run on. Most of it is all low speed driving. Team Mugen was out here this past weekend and Mike S' fastest lap times were in the 22 second range. If you saw how Mike and Brian T. went around people at these lower speeds, you would agree with me.
#8959
Originally Posted by rmdhawaii
When I get a chance ( ) I will measure the steering throw on the MTX-4 and compare it to that of the RRR. If I recall correctly, the MTX-4 doesn't have a problem with scraping the bottom of the shock ball cup like the RRR. That may something to do with it.
To solve that "Shock Ball" problem on the RRR, I simply use a file to shave down and also round the inner edge of all my front wheels when truing my tires.
This allows me to have full steering lock without cutting the shock ball ends.
Hope this helps.
#8960
Originally Posted by V1-RRR-WC
Hi RMD,
Hope this helps.
Hope this helps.
#8961
Thanks, that's a great tip. It's been mentioned before (probably by you), but I just have not gotten around to doing it. I will certainly give it a try.
It's the least I can offer for all the great tips you have provided the RRR community.
#8962
what type of grease should I use on the bearing that's on the outside of the clutch bell? It's an open bearing, not sealed in any way. I don't know the name of this, but when you loosen the nut it comes out. Is there a certain type of grease that is better than others?
Also I noticed a slight noise when my car rolls to a stop, it's almost like you would hear if a part was spinning and I can't tell where it's comming from and don't know if it's normal. Hard to explain what I mean, but if you lift the car up and listen carefully when pumping the throttle to spin the wheels you can hear it. It sounds like plastic (dull sounding not ringing like metal). My only guess is it's the gears clattering a bit but I am not sure. The car seems to run well and this noise hasn't appeared to be a broken part or something loose, I checked everything over 3 times.
#8964
http://www2.towerhobbies.com/cgi-bin...?&I=LX2880&P=M
#8965
22 seconds is a very long lap. You should try opening that track up and let those cars run a little.
#8968
Jag / Ivan: Sometimes it's a little more flowing, but there is only so much you can do with a 150x80 ft space. I once added a second straight and that sped things up quite a bit. The track is very challenging and provides for some really great racing.
I'm not involved in track layout anymore. I just help tape down the track these days.
#8969
Originally Posted by mrgsr
Dredd
I found mugen super grease to work best! you want to keep this bearing clean and greased at all times
not sure what that dull sound is, check your gear mesh it could betoo tight or maybe you have a work pinion somewher?
